RoadkillUK Posted April 5, 2015 Share Posted April 5, 2015 Sorry about this, but this is a continuation from http://www.fordownersclub.com/forums/topic/69150-2006-18-tdci-wont-start-code-p0089/ The car still refuses to start, I have done the following. Replaced the filter Used a vacuum hose to pull fuel through from the tank Replaced the Fuel Rail Pressure Sensor Replaced the Fuel Pressure Regulator Replaced the Fuel Metering Valve There's more below the pic ... As you can see by the following photo, I have totally bypassed the tank, fuel line and fuel filter by using a funnel and short piece of clear pipe. As I crank the engine the fuel goes down slowly but that car makes no attempt to start. Here is another pic of the parts I have replaced ... I did notice that when I replaced the Fuel Rail Pressure Sensor, I started to get a reading when previously it was at 0. So, what I'm asking now is ... and I don't want to ... do we think all this points to the fuel pump needing replacing? I have a fuel pump that I collected yesterday after a 4 hour round trip, that is where I got the sensors from, also I got the fuel rail too, is it worth swapping out the fuel rail? Thanks, Lee. Quote Link to comment Share on other sites More sharing options...
iantt Posted April 5, 2015 Share Posted April 5, 2015 have you checked the wiring to the fuel rail pressure sensor? Quote Link to comment Share on other sites More sharing options...
RoadkillUK Posted April 5, 2015 Author Share Posted April 5, 2015 Ok, job done, fixed, sorted. Turns out that the original problem was the Fuel Rail Pressure Sensor, it was reading 0 at all times, when it should be fluctuating, the reason it wouldn't start after replacing this was air in the system. As you can see by my previous post ^^^ that I used a funnel and piece of pipe to fill the fuel hose, I was actually testing to see if the low pressure pump was sucking. Anyway, sorted. Hope this helps someone. Lee. Quote Link to comment Share on other sites More sharing options...
