Reynolds20 Posted April 10, 2015 Share Posted April 10, 2015 Hi to all my ford brothers and sisters! Having a serious problem with my fan and water cooler, which is really P'ing me off! Basically, my fan isn't coming on to cool my car down, hence my water expanding too much and is spurting out the lid only little amounts but enough to drain the water in half hour! I've had my thermostat changed and this didnt solve the problem, I Reset my ECU because i thought it was faulty and wasn't telling the fan to switch on etc still no resolve. my gauge on my car doesn't go high, starts off in the morning at minimum, and is warm by the time i get to work only 2 miles away, then moves up 2 notches to in the middle which is running temperature i presume? I realllly need help for this as its making me want to sell my car as I cant even drive 15 miles to my partners house without my water bottle steaming and alot of water lost. the fan used to come on but I haven't heard it in a while Is there any suggestions or anyone who has had problems with this that could help as if not I'm going to up and sell and go German... Quote Link to comment Share on other sites More sharing options...
Reynolds20 Posted April 10, 2015 Author Share Posted April 10, 2015 Also it has A/C and when i turn this on the fan still doesn't come on as suggested from other forums... Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 21, 2015 Share Posted April 21, 2015 You need an expansion cap replacement to sort out the expansion leak as for the fan have you checked voltage getting to it? Quote Link to comment Share on other sites More sharing options...
mintalkin Posted April 22, 2015 Share Posted April 22, 2015 it could be a temp sender unit or a water pump problem. Quote Link to comment Share on other sites More sharing options...
BamBam2140 Posted April 23, 2015 Share Posted April 23, 2015 I just had this exact problem with my 2005 Ford Focus, I went thru all the fuses and diodes, Checked the relays and even pulled out the fans and hooked 12 volt to them, I found out there is a resistor mounted on the fan shroud, If you Jack the front end of the vehicle up its located right in the middle of the two fans towards the bottom of the shroud. Radiator fan motor relay kit, Napa auto parts # 600-6010, $40.00, Comes with the resistor and a new harness plug and two butt connectors. In order to get to the resistor it necessary to drop the fans thru the bottom of the vehicle because you remove the one 10 mill bolt from the front side favoring the radiator, Hope this helps... If you need detailed step by step just ask Quote Link to comment Share on other sites More sharing options...
AdeMk1 Posted April 23, 2015 Share Posted April 23, 2015 Bam beat me to it! I was going to suggest the fan resistors, you can buy then 2nd hand from a breakers. Other possible causes could be the water pump as someone has already mentioned, or head gasket failure. I say this as you don't say that your car is overheating at all, just that its pouring water out of the expansion tank, could point to head gasket failure between a water jacket. Best to get it checked over by a mechanic to pinpoint the problem really. Quote Link to comment Share on other sites More sharing options...
