AmiZaKi Posted April 17, 2015 Share Posted April 17, 2015 Hi, i am a new driver and my first car ford focus 55 model. Using this car for 6 months...from yesterday morning, i suddenly found my car charger point is not working. I was using that point regularly to listening fm transmitor mp3 player... First i thought that transmiter dead... But today after checking with iPhone charger and sat nav... Found, there is no connection at all on that point... I am worried as this is first time i faced this kind of problem... Do you have any idea what kind of problem it can be ??? If its bettery problem there should be battery sign on the display... Isn't it ??? Nothing found.... Please if you know what might be the reason of this kind of problem.... Please let me know.... Thanks in Advance.... Zak Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted April 17, 2015 Share Posted April 17, 2015 Blown fuse ? 1 Quote Link to comment Share on other sites More sharing options...
samfiestaperv Posted April 17, 2015 Share Posted April 17, 2015 I'm assuming you mean the cigarette charger socket? Have you tried the fuse? It's simple to replace, if it's like the fiesta the fuse box is in the glove compartment, I presume it's the same, you have to squeeze the sides a little to open it fully - empty the glove compartment first though or the contents end up all over the floor!! - there should be a map of fuses, what amps and exactly where it goes. There may be more than one 12v charger point looks like a cigarette lighter symbol on the map Hope it works, good luck Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 17, 2015 Share Posted April 17, 2015 The mk2 Focus fusebox is inder the glovebox. Twist the two tabs and the board drops down. Pull the board towards you so the rear tabs drop into slots then the board will hinge down through 90 degrees for easier access to the fuses. You want to check fuse 39 which is a pale yellow (20 amp). Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 17, 2015 Share Posted April 17, 2015 2 Quote Link to comment Share on other sites More sharing options...
AmiZaKi Posted April 17, 2015 Author Share Posted April 17, 2015 Thanks... Yea cigarette charger socket.... Ok, i will check fuse box tomorrow.... If that fuse problem... From where i can buy the fuse & is it 12v ??? Quote Link to comment Share on other sites More sharing options...
samfiestaperv Posted April 17, 2015 Share Posted April 17, 2015 Just about any car place and most local petrol stations too Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 17, 2015 Share Posted April 17, 2015 All the fuses are 12v. For the footwell board you need 'Mini' Blade Fuses Quote Link to comment Share on other sites More sharing options...
AmiZaKi Posted April 17, 2015 Author Share Posted April 17, 2015 Thanks Guys Quote Link to comment Share on other sites More sharing options...
stuart.howden Posted December 29, 2019 Share Posted December 29, 2019 Hi hope someone can help me.. My 12v sockets don't work but tried 3 fuses please help l Quote Link to comment Share on other sites More sharing options...
johnH Posted December 29, 2019 Share Posted December 29, 2019 Original post is from 2015. Can you please create own thread with full details. 1 Quote Link to comment Share on other sites More sharing options...
