ralph Posted April 19, 2015 Share Posted April 19, 2015 Got a parking sensor fault (long beep, flashing dash light on button then system switches off). I have 3 questions: 1 are the sensors same on front and back? There are sellers on eBay selling "ford parking sensors" but I have been told they are different part numbers depending whether they are front or back, and how high they are off the ground!!!??? 2 how can you tell which sensor is faulty without access to a laptop? 3 Anyone know the correct ford part numbers? Thanks everyone out there Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 28, 2015 Share Posted April 28, 2015 1) a sensor is a sensor, however tolerances for Ford units and those tolerances in the senor head all ad up and can make a diference. In which case, your best bet is going ford. 2) unplug each sensor at a time until the display and tones change significantly for one. 3) I cant help with the Ford part number, but google eacatparts, and you can use the mondeo, then accessories, then you should have the part numbers there. Alternatively, call Ford and get the part details and prices off them. Quote Link to comment Share on other sites More sharing options...
ralph Posted April 29, 2015 Author Share Posted April 29, 2015 Hi Turns out sensors are fine.... Broken wire going to the sensor connector. New wiring loom for sensors( £40) and all is ok!! Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 29, 2015 Share Posted April 29, 2015 That's not a bad price for the wiring.... Quote Link to comment Share on other sites More sharing options...
