xcd Posted April 20, 2015 Share Posted April 20, 2015 Hi guys, looking to fix up the remaining niggles on my Mk1. Aircon button light comes on but air is no colder, seems to dry the air though as helps to demist, so is it just a re-gas that's needed? Heated front windscreen, works great on the passenger side, demists in seconds, drivers side takes 5-10 mins if at all (less of an issue now the weathers improved). Electric windows, passenger window works fine with it's own controllers, but drivers side button can only put the passenger window up, not down (just contact cleaner needed?). Thanks. Quote Link to comment Share on other sites More sharing options...
ljm183 Posted April 20, 2015 Share Posted April 20, 2015 Aircon possible regas Heated screen, if it,s the same as a later model, wiper arm damaged the wiring http://www.fordownersclub.com/forums/tutorials/article/18-ford-focus-06-heated-screen-drivers-side-failure-real-reason/ Window switch try cleaner, but probably dodgy switch. Quote Link to comment Share on other sites More sharing options...
xcd Posted July 14, 2015 Author Share Posted July 14, 2015 Thanks, spoke to the old owner and they tried a regas once and it lasted a day or two then stopped so imagine there's a leak, might look into tracking this down, depends on cost. Thanks for the windscreen link will look into that. Switch wise I'll give contact cleaner a go, if not I imagine a new switch should be easy enough. Also made a new thread here for another issue, in this section as well. Cheers. Quote Link to comment Share on other sites More sharing options...
