dimmy Posted April 27, 2015 Share Posted April 27, 2015 Hi! I just bought a 2007 Ford Focus collection and i have a problem how to set up aux cables. I have read and read every forum and called a few ford retailers but they dont have a clue how to continue. http://i.imgur.com/pKDRsVX.jpg http://i.imgur.com/CWCMWdM.jpg So far i have understood that this cable is a aux cable which is prefitted in my car, if so what is my next move? which part i have to buy and do i still have to remove the radio? English isnt my first language so break it down as much as you can =). This has been a week long battle and my wife is getting anxious because all i do is trying to figure this out.. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 27, 2015 Share Posted April 27, 2015 That is not the aux cable, it's a connector for a passenger airbag deactivation switch. P/M me your postal details and I'll send you my old aux connector I stripped out of my previous car (free of charge). It has a 3.5 plug on the end which you can tun into the glovebox for easy connection. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 27, 2015 Share Posted April 27, 2015 To fit the cable you need to pull the radio trim off and then undo 4 screws (most likely Torx type). Pull the radio forward and then plug the connector block into the blank socket.- No need to disconnect the main radio connector, just gently push the connector in straight (don';t bend the pins) until it locks in place, you may need to pull the aerial connector off for easier access (tends to be short) and don't forget to re-attach it. Quote Link to comment Share on other sites More sharing options...
