landy39 Posted April 27, 2015 Share Posted April 27, 2015 Hi all car runs sweet but the ABS light has come on,put code reader on and has come up P0500 ...... vss ..... but speedo and all the dials working fine ..... car is Focus 06 MK2 1.6tdci .... am i right in thinking it could be a ABS ring on one of the cv's may need replacing . ....? Any thoughts peeps. cheers tony Quote Link to comment Share on other sites More sharing options...
JW1982 Posted April 27, 2015 Share Posted April 27, 2015 The focus MK2 does not have a VSS. The speed is calculated by the BCM (brake Control Module which is mounted on the ABS pump.) and distributed to the other modules which need the speed signal over the CANbus network. A defective ABS sensor or an incorrect ABS sensor signal should generate different DTC codes. Personally I would suspect the BCM/ABS module itself or a wiring problem. 1 Quote Link to comment Share on other sites More sharing options...
landy39 Posted April 27, 2015 Author Share Posted April 27, 2015 The focus MK2 does not have a VSS. The speed is calculated by the BCM (brake Control Module which is mounted on the ABS pump.) and distributed to the other modules which need the speed signal over the CANbus network. A defective ABS sensor or an incorrect ABS sensor signal should generate different DTC codes. Personally I would suspect the BCM/ABS module itself or a wiring problem. cheers will check the wiring and take it from there. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted May 12, 2015 Share Posted May 12, 2015 I had a similar issue on the CMAX, iot was the short loom from the main loom down to the ABS sensor that was at fault. Replaced for £55 and done and dusted. 1 Quote Link to comment Share on other sites More sharing options...
landy39 Posted May 12, 2015 Author Share Posted May 12, 2015 just an update ....... it was the front right impulse ring that was at fault ..... i used ConfigELM and it came up with C1142 Wheel Speed Sensor RF Tone Ring Tooth Missing Fault ...... while i was in the area i changed the front wheel bearing also as it was growling abit ....... light out all good. 1 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted May 12, 2015 Share Posted May 12, 2015 result! 2 Quote Link to comment Share on other sites More sharing options...
