nathmogz7 Posted April 28, 2015 Share Posted April 28, 2015 Hi all, picked up my fiesta st yesterday and was wondering how i set the DAB radio up. It says Block 1A, Block 1B, anyone know what these mean and how i set it up? all help much appreciated. Thanks, Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted April 28, 2015 Share Posted April 28, 2015 I've always been confused by the DAB as well lol. You can search through the different "blocks" to find different stations but I think there's probably a way to set your favourite stations. I've never bothered because I either listen to my own music or local BBC radio. Hope you're enjoying the ST anyway :) Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 28, 2015 Share Posted April 28, 2015 The handbook pack has a decent radio manual in with it. Quote Link to comment Share on other sites More sharing options...
nathmogz7 Posted April 28, 2015 Author Share Posted April 28, 2015 ive read the handbook and theres nothing in there saing about the different blocks. i.e block 5a, block 6a etc Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 28, 2015 Share Posted April 28, 2015 Blocks on a DAB radio are basically different frequency ranges. On a standard FM radio each station is analogue so has to be on it's own frequency. DAB radios work differently, as the signal is digital you have more than one station transmitting on each available frequency. The blocks are basically each frequency allocated to DAB transmission within which a handful of subscribing broadcasters are licensed to transmit. Certain blocks may be empty due to that frequency being un-allocated or because it is held for another country to transmit on. Basically, if you don't have any channels transmitting in certain blocks just skip them. A full rescan occasionally will help to ensure that you have all the available channels in your area. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted April 28, 2015 Share Posted April 28, 2015 http://www.radio-electronics.com/info/broadcast/dab/dab_frequencies.php Quote Link to comment Share on other sites More sharing options...
MattDRX Posted April 28, 2015 Share Posted April 28, 2015 Press list and it will pick up a fair few automatically, generally you have to be on DAB1 for most mainstream stations, other than that just press and hold the right arrow to scroll through and pick them up, pressing it seems to just scroll to another blank station. Quote Link to comment Share on other sites More sharing options...
nathmogz7 Posted April 28, 2015 Author Share Posted April 28, 2015 Thanks for your comments, where is the list command? Thanks again Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
MattDRX Posted April 28, 2015 Share Posted April 28, 2015 it will show at the bottom of the screen, it say List, it's one of the 4 constant buttons at the bottom, same ones you use to scroll between SAT NAV address input, like numbers and letters etc Quote Link to comment Share on other sites More sharing options...
nathmogz7 Posted April 28, 2015 Author Share Posted April 28, 2015 Ok cheers mate, will check when I finish work! Thanks Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
