jace1969 Posted April 29, 2015 Share Posted April 29, 2015 What fuse to use for direct live ( 24/7 ) on a piggy back for tracker. Have piggy back fuse for ignition wired up on hard wire but need a live on 24/7 for hard wire kit. Thanks Quote Link to comment Share on other sites More sharing options...
negendahl Posted April 29, 2015 Share Posted April 29, 2015 I think the easiest way is to tun off the ignition and just test the empty slot with a tester - i guess what slots are available and so on is depending on what kind of equipment you have. I did a similar process when i had to hardwire a USB charger, took me around 5 minutes to find a slot :) Quote Link to comment Share on other sites More sharing options...
jace1969 Posted April 29, 2015 Author Share Posted April 29, 2015 I think the easiest way is to tun off the ignition and just test the empty slot with a tester - i guess what slots are available and so on is depending on what kind of equipment you have. I did a similar process when i had to hardwire a USB charger, took me around 5 minutes to find a slot :) I do have a screwdriver tester and a lot of spare slots,thought most of them are dead slots but must be wrong. I was going to try the cigi lighter one but it's a larger fuse by the look of it. Quote Link to comment Share on other sites More sharing options...
negendahl Posted April 29, 2015 Share Posted April 29, 2015 Ah, okay. Did you check your manual? It says the functions of most of the slots. Quote Link to comment Share on other sites More sharing options...
jace1969 Posted April 29, 2015 Author Share Posted April 29, 2015 Yes i have had a look but i don't want to put it onto something if it blows it takes out something i need. Saying that i have found 2 spare slots,1 seems live all the time but thinking how to test the wires when connected as the end is a weird u.s.b type and the tracker don't give you a light when connected,put 2 amp fuse in. Quote Link to comment Share on other sites More sharing options...
