STUG38 Posted May 3, 2015 Share Posted May 3, 2015 I have a 2008 Mk2.5 Focus TDCI. I read the DTC codes this afternoon with ELMCONFIG as the power seemed down. I got the codes P2458, P0299, P0087, P2459, P1180. I googled what each means and seems to be pointing to several problems. But I really dont know where to start to sort it out. Any advice would be much appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
WES180 Posted May 3, 2015 Share Posted May 3, 2015 You might have more of a chance of someone helping you out if you post what the codes meant too. Only a thought.B) Quote Link to comment Share on other sites More sharing options...
STUG38 Posted May 3, 2015 Author Share Posted May 3, 2015 Thanks. Hadnt thought of that. P2458 Diesel Particulate filer regeneration duration P0299 Turbo under boost P0087 Fuel rail/system pressure too low P2459 Diesel Particulate filter regeneration frequency P1180 Fuel delivery system malfunction low Thanks Quote Link to comment Share on other sites More sharing options...
dezwez Posted May 3, 2015 Share Posted May 3, 2015 clear the codes then see what comes back up you may have old codes that have not been cleared Quote Link to comment Share on other sites More sharing options...
Goodkat Posted May 3, 2015 Share Posted May 3, 2015 Looks like you have a dpf issue to start with, the others may be a consequence of that, otherwise maybe fuel pump on way out? Quote Link to comment Share on other sites More sharing options...
STUG38 Posted May 3, 2015 Author Share Posted May 3, 2015 Thanks. That's kind of what I was thinking. DPF more than fuel pump. Once engine is warm it seems to have more power. Not entertaining idea of deleting DPF so either replacement or cleaning. Any suggestions? Thanks Quote Link to comment Share on other sites More sharing options...
Goodkat Posted May 3, 2015 Share Posted May 3, 2015 Word is Terraclean is supposed to help with dodgy dpfs, I am trying to persuade my brother to take his leggy mk4 mondeo with dpf issues to a Terraclean outfit so I can find out for certain. Google it and see what you reckon. Sent via the 'Clacks' GNU STP 1 Quote Link to comment Share on other sites More sharing options...
John2015 Posted May 3, 2015 Share Posted May 3, 2015 Hi can you tell me what mileage the car has done Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
STUG38 Posted May 3, 2015 Author Share Posted May 3, 2015 Thanks. I come across terraclean for DPF and have emailed for a quote to remove, clean, refit and clear all codes. The car has done 57500 miles. Quote Link to comment Share on other sites More sharing options...
John2015 Posted May 3, 2015 Share Posted May 3, 2015 I had the same problem as you're having ended up with a new DPF fitted hope you get yours sorted out Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
STUG38 Posted May 3, 2015 Author Share Posted May 3, 2015 Thanks. If you don't mind me asking what did it cost to have your DPF replaced? Quote Link to comment Share on other sites More sharing options...
John2015 Posted May 3, 2015 Share Posted May 3, 2015 Hi I took it to the ford garage in Bolton 800 pounds with a 12 month warranty Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
John2015 Posted May 3, 2015 Share Posted May 3, 2015 I have only had it done 2 months ago with 56000 miles on the clock but I must say vary pleased with now Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
STUG38 Posted May 4, 2015 Author Share Posted May 4, 2015 Just had a quote for £250 to have DPF cleaned with Terraclean. Includes removal, refitting all codes cleared, active regen, pre and post flow tests and six month warranty. Just waiting on quotes for replacement now. Quote Link to comment Share on other sites More sharing options...
mudman Posted May 4, 2015 Share Posted May 4, 2015 From what I've seen they don't remove anything just conect there machine to it , try an get it sorted sooner rather than later I had dpf issues which resulted in my turbo blowing Quote Link to comment Share on other sites More sharing options...
