MartynS Posted May 5, 2015 Share Posted May 5, 2015 Is it possible to disable the chime you get when the ignition is on but the drivers door is open? I've tried the obvious thing of disabling both info and warning chimes in the menu but this made no difference. It's so annoying when using the car vac having it bonging away for ages! Quote Link to comment Share on other sites More sharing options...
MattDRX Posted May 5, 2015 Share Posted May 5, 2015 Why do you need the ignition on when hovering the car? Quote Link to comment Share on other sites More sharing options...
MarksST Posted May 5, 2015 Share Posted May 5, 2015 12v car vac probably. 1 Quote Link to comment Share on other sites More sharing options...
MartynS Posted May 5, 2015 Author Share Posted May 5, 2015 Yeh, for some reason the vac never works without the ignition on. Phone charger does though, unless I've already tried the vac in which case the phone doesn't work either. No idea what's going on there! Quote Link to comment Share on other sites More sharing options...
matt1981 Posted May 5, 2015 Share Posted May 5, 2015 The rear socket doesn't need the ignition on Quote Link to comment Share on other sites More sharing options...
Well Spoken Waffle Posted May 5, 2015 Share Posted May 5, 2015 the fiesta has a rear socket? imma check this tomorrow morning Quote Link to comment Share on other sites More sharing options...
MartynS Posted May 5, 2015 Author Share Posted May 5, 2015 Yeh it's on the back of the centre console/armrest. And the vac doesn't work in that one either with the ignition off. Quote Link to comment Share on other sites More sharing options...
matt1981 Posted May 5, 2015 Share Posted May 5, 2015 Sounds like you have a problem then, that one is always on, I use my vac with that one and no ignition Quote Link to comment Share on other sites More sharing options...
