Alex12345 Posted May 9, 2015 Share Posted May 9, 2015 Hello new to this website but we have tried everything our garage has suggested and the fault code just keeps coming back. We have a ford ka style 2006 and the fault code p0420 keeps appearing we've changed both lambda sensors and had a new new cat converter fitted,We had full service changed spark plugs oil etc. But still the problem keeps coming back the garage have run out of ideas and just say we should sell the car! We feel we've spent too much money on it just to give up now and are adamant it can be fixed. Any help would be greatly appreciated. Bare in mind I'm not particularly savvy with mechanical lingo so be as simple as you can. Thanks Quote Link to comment Share on other sites More sharing options...
Dan62 Posted May 9, 2015 Share Posted May 9, 2015 It would be worth checking the HOS fuse F30 (10A) You have to drop the fusebox to get to it and its the top right hand side fuse. This link should help you with access to the fuse http://www.fordownersclub.com/forums/topic/20365-streetka/ Quote Link to comment Share on other sites More sharing options...
iantt Posted May 9, 2015 Share Posted May 9, 2015 im assuming you mean p0420 , not p04020, cat efficiency below threshhold. what you or your garage needs to do is check the outputs of both the sensors on ociliscope to see what wave forms are on both sensors.this will check if the new cat is working ok and both sensors are doing there job or not if thats the case no other dtcs? Quote Link to comment Share on other sites More sharing options...
iantt Posted May 9, 2015 Share Posted May 9, 2015 It would be worth checking the HOS fuse F30 (10A) You have to drop the fusebox to get to it and its the top right hand side fuse. This link should help you with access to the fuse http://www.fordownersclub.com/forums/topic/20365-streetka/ would have thought blown fuse would trigger heater circuit dtcs on both sensors , but may not, worth checking Quote Link to comment Share on other sites More sharing options...
Alex12345 Posted May 9, 2015 Author Share Posted May 9, 2015 Yes sorry it must be the p0420 I did it from memory. I will try the fuse and ask at the garage when I neXT take it in. Thank you Quote Link to comment Share on other sites More sharing options...
Dan62 Posted May 9, 2015 Share Posted May 9, 2015 would have thought blown fuse would trigger heater circuit dtcs on both sensors , but may not, worth checking That's a very good point, was just a suggestion as everything seems to have been changed and as this fuse is hidden thought it could have been overlooked. Quote Link to comment Share on other sites More sharing options...
Alex12345 Posted May 9, 2015 Author Share Posted May 9, 2015 Just checked the fuse And it's fine thanks though was worth a try Quote Link to comment Share on other sites More sharing options...
delboy Posted May 10, 2015 Share Posted May 10, 2015 get the exhaust manifold checked Quote Link to comment Share on other sites More sharing options...
Alex12345 Posted May 11, 2015 Author Share Posted May 11, 2015 Thank you delboy I will the next time I take it in I think the Mrs has it booked it this week Quote Link to comment Share on other sites More sharing options...
