Shorty7589 Posted May 22, 2015 Share Posted May 22, 2015 I have a 2003, pre june 2003, 03 plate mondeo tdci 2.0 130, it has had the injectors replaced, fuel pump replaced, fuel filter replaced and injectors programmed, it starts and runs very rough like only on 3 cylinders or something but when you switch it off and restart it it runs a lot better but still missfires at mid to high revs, the fault code that comes up when started the first time and running rough is P0200, once stopped and restarted there are no fault codes, it has the EGR valve blanked off, i had it ticking over and when i unplugged the MAF sensor there were no changes at all, surely it should make a little difference as other cars when i've done this they've spluttered on then cut out, any advice/help would very much appreciated. Thanks Dan. Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted May 23, 2015 Share Posted May 23, 2015 P0200 is injector circuit malfunction & commonly is an electrical fault. Quote Link to comment Share on other sites More sharing options...
Shorty7589 Posted May 23, 2015 Author Share Posted May 23, 2015 Any ideas as to where i should start looking? MAF? EGR? etc Thanks Dan. Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted May 23, 2015 Share Posted May 23, 2015 Problem is that it's a bit of a generic code - google P0200 & you'll see a list of possibilities , I suggest you start with the easiest & cheapest first. Quote Link to comment Share on other sites More sharing options...
