AdBlock Warning
Sign in to follow this
Followers 0
gaz6076
Radio showing reg no?
3 posts in this topic
Remove a battery from a focus today and when I put it back in turned on the radio to input the code when it showed up this...
Any one came across this before? I certainly haven't :blink:
Some Ford radios show a car registration number or even a series of meaningless characters at switch on. its just a security check for the main dealers to prove the correct radio is fitted. If this is the case, press the SELECT button which will change the display to CODE - - - - and proceed to enter the code
I managed to get the code in ok. Was just wondering if this was common. Just I've ever seen it before
Followers 0
