b4zz Posted May 14, 2017 Share Posted May 14, 2017 loving he wall paper. look forward to seeing the alloys in panther black will set the whole car of then. good luck with the house 1 Quote Link to comment Share on other sites More sharing options...
kpg Posted May 30, 2017 Author Share Posted May 30, 2017 Does anyone have any idea what these codes stand for ?Tried Google but no definite answer. Also, literally as soon as turn the ignition on the car without starting the engine it flashes up battery low warning. Yet there are no starting issues or any other symptoms. battery level in the hidden menu says 11.2volts.Any ideas ? Quote Link to comment Share on other sites More sharing options...
Victory Posted May 30, 2017 Share Posted May 30, 2017 would say thats quite low for the battery mine says 13.9 .. think your in need of a new one .. has it been changed at all ever? 5 years is about the right time for new one. 1 Quote Link to comment Share on other sites More sharing options...
kpg Posted May 30, 2017 Author Share Posted May 30, 2017 would say thats quite low for the battery mine says 13.9 .. think your in need of a new one .. has it been changed at all ever? 5 years is about the right time for new one. Hasn't been changed as far as I know. Would you recommend having ford do it or just buy the battery and change it myself ?Any suggestions on which battery to get lads ? Sent from my HTC 10 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Victory Posted May 30, 2017 Share Posted May 30, 2017 i changed it myself it's not too hard to do , bought from Halfords. Quote Link to comment Share on other sites More sharing options...
andypsp Posted May 30, 2017 Share Posted May 30, 2017 have you checked the battery in the key-fob as it may be that batt that needs replaceing and not the car batt Quote Link to comment Share on other sites More sharing options...
Guzzilazz Posted May 31, 2017 Share Posted May 31, 2017 If the car battery is 11.2v it's toast. A healthy battery that's rested over night should be 12.7-12.8, AGM's maybe a bit higher 3 Quote Link to comment Share on other sites More sharing options...
kpg Posted May 31, 2017 Author Share Posted May 31, 2017 If the car battery is 11.2v it's toast. A healthy battery that's rested over night should be 12.7-12.8, AGM's maybe a bit higher She-height!Right so what do you recommend for a replacement ? Bosch something ? Quote Link to comment Share on other sites More sharing options...
tazzman600 Posted May 31, 2017 Share Posted May 31, 2017 I recommend you go on kwikfit website. Punch in your car details and find batteries and at least 2 will show up. I got mine from them and it's been bob on excellent. I went for 2nd of 3 for my tit x sport ecoboost mondeo. Booked it in online and they fitted it and a 5yr g/tee plus £25 off a service should I take it there. 2 Quote Link to comment Share on other sites More sharing options...
phillip123hastings Posted May 31, 2017 Share Posted May 31, 2017 kwkfit is a solid source! Quote Link to comment Share on other sites More sharing options...
kpg Posted June 1, 2017 Author Share Posted June 1, 2017 Well how did things go?? [emoji52]Sent from my iPhone using Tapatalk Hi Pal, where did you get those stick on vents for your st ? Have you still got a link to them ? I fancy checking them out. Quote Link to comment Share on other sites More sharing options...
yunii Posted June 3, 2017 Share Posted June 3, 2017 She-height! Right so what do you recommend for a replacement ? Bosch something ? Something like varta, Bosch, Exide,Yuasa are quality. But ensure its calcium technolgy. Check eurocarparts as well. Yunii Sent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
kpg Posted June 4, 2017 Author Share Posted June 4, 2017 Well the battery is definitely on its way out. Had to be jumped 3 times this weekend so it's not holding a charge. One of those time was at Ford Fair today amongst all the classics that started first time lol embarrassing. I'll be getting the battery tasted tomorrow and hopefully it'll just be a new one I'll need. Quote Link to comment Share on other sites More sharing options...
kpg Posted June 4, 2017 Author Share Posted June 4, 2017 Some pics from Causeway Coast Ford Fair today:Any my car sporting new stripes and fixed door wrap: 3 Quote Link to comment Share on other sites More sharing options...
b4zz Posted June 4, 2017 Share Posted June 4, 2017 the car is looking good and like the stripes. looked a good show shame about the weather Quote Link to comment Share on other sites More sharing options...
alonimous Posted June 4, 2017 Share Posted June 4, 2017 Looking good Sent from my HTC One M9 using Tapatalk Quote Link to comment Share on other sites More sharing options...
kpg Posted June 6, 2017 Author Share Posted June 6, 2017 So finally got around to getting a battery for the car. After being jumped 3 times over the weekend enough was enough. The mechanics next door to work fitted a new Yuasa battery for £60 all in. Wasn't too bad i thought. Worked a treat too. Sent from my HTC 10 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Dan P Posted June 7, 2017 Share Posted June 7, 2017 Car looks great. Loving the wrap!Glad you got the battery sorted - it's no good having your motor shown up by all the old classics starting first time! 1 Quote Link to comment Share on other sites More sharing options...
kpg Posted July 5, 2017 Author Share Posted July 5, 2017 6 Quote Link to comment Share on other sites More sharing options...
b4zz Posted July 6, 2017 Share Posted July 6, 2017 looking good Quote Link to comment Share on other sites More sharing options...
WAZ91 Posted July 6, 2017 Share Posted July 6, 2017 Quick quesey, how difficult was it to wrap the car? I found it hard enough doing small bits inside 1 Quote Link to comment Share on other sites More sharing options...
kpg Posted July 6, 2017 Author Share Posted July 6, 2017 Quick quesey, how difficult was it to wrap the car? I found it hard enough doing small bits inside I found it easy enough. There are certain things you can do to cheat but overall it's just more time consuming than difficult. For example the front bumper has so many recesses and curves around the grill so I just cut them out, didn't bother wrapping that area and left it like a wide mouth grill effect. Patience is key. 1 Quote Link to comment Share on other sites More sharing options...
Ubetcha Posted July 9, 2017 Share Posted July 9, 2017 Hi KPG, I've been really interested reading this entire thread and watching your progress.. it's certainly been some change from where you started. Happy anniversary btw and congrats on the new home. If there are any meets coming up I'd certainly be interested in accompanying you (as I myself am only an hour and a half away from you) which I'm aware is a little off thread so let me get back on track. I'm looking forward to hearing some more of your progress and I'll bookmark this thread. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
kpg Posted July 9, 2017 Author Share Posted July 9, 2017 @Ubetcha Thanks for showing an interest in my thread [emoji4] ! I'm new to attending meets in a way, I've only ever been to twice, to the same one lol but if I hear of any I'll be sure to post in here [emoji4]Sent from my HTC 10 using Tapatalk Quote Link to comment Share on other sites More sharing options...
yunii Posted July 10, 2017 Share Posted July 10, 2017 Kpg , Cars looking absolutely Awesome! Loving the nice touches.That strip decal along the doors do they say Titanium-S ?Cos i had a template custom made as well as illumenated door sills.YuniiSent from my SM-G925F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
