Misty Reverse Camera
jace1969
 Share
As in title,my reverse camera is a bit misty.
Washed the car the other day and a very slight mist on the top part when you look at the picture
Camera is new from ford 4 months ago as was done under cover so free.
Its the genuine one as on from new and in mirror,works fine with all lines etc.
Don't spray water direct on it and try not to wash it but it does and will get wet.
Any advice would be great as still under cover until october 20th.
It's like damp but it's a sealed lense in a plastic cover.
Link to comment
Condensation.
Link to comment
Condensation.
Whats the best was to solve this,hair dryer or some sort of heat.
Is this common when you wash your car.
Link to comment
Seems fairly common - I've not found a permanent cure - yet
Link to comment
How have you sorted yours out,it's all ok but the pic on the mirror is like a slight mist on the top part.
All lines there.
Link to comment
I just avoid getting them wet, Focus ST is better than TXS for some reason - i'll find a permanent cure when I find the time.
Link to comment
Hi
If its still under guarantee I would take it back, I have had security cameras steam up, it needs to be taken apart cleaned and put back together, may need a new sealing ring, or seal with clear silicone. It has to be water tight, or it will keep steaming up, You will find the moisture is trapped in the camera.( on a warm day it may go but come back when cold)
Small cameras are difficult to repair, just had to repair a infra red shutter on a camera after I dropped it, I thought it would never work again. A bit of super glue on the lever to the solenoid sorted it out.
Barry T
Link to comment
Hi
Barry T
How can you not get it wet lol. :)
When you wash it you avoid is as much as you can and i don't hose pipe it just round it but still goes on
Also when it rains and if it's heavy rain your stuffed.
I might just pop it back ''again'' to be honest getting a bit sick of it,it's been in twice all day for this and i need the car
24/7.
Link to comment
Gave it a quick blast with a hair dryer for about 5 mins then left it,tried it
an hour after and seems o.k now,looking at something to pop over it when i wash it.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
