AdBlock Warning
Sign in to follow this
Followers 0
GeeDee
Leaking Air Con
3 posts in this topic
My daughter has advised that when her air con (Y Reg 1.2) has started leaking water into the car when it is on.
I'm assuming it is the condensate and that the drain pipe has either become disconnected or is leaking some how.
Before I start investigating, can anyone point me in the right direction?
Does it smell a bit like anti freeze..............if so then its probably the drain tube blocked I had the same problem with my mondeo....but I cant tell you exactly where the drain tube is......sorry :(
As of yet, I have not seen or smelt it - currently running the engine to try to recreate the problem.
Followers 0
