Door seals
#1
Posted 09 May 2008 - 06:16 PM
A friend has just purchased an 06 plate 1.8 petrol which has done about 9,000 miles. His doors started squeaking badly just after he had purchased from main dealer. Despite the dealer fitting new door seals the noise returned after a few days.
The squeak appears to be coming not from the main door seals but from the seal running along the top of the door. If you press the door from the outside it is quite 'squeaky'. Any ideas on a permanent solution?
Brian
#2
Posted 31 July 2008 - 04:30 PM
#3
Posted 30 August 2008 - 08:28 PM
#4
Posted 08 November 2008 - 03:42 PM
it is the top of the seals rubbing against the body what you need is some teflon tape and stick it on the body from front door to the back door make sure there is no silicone on the seals if so remove with silicone remover the roll of tape is avaliable at any bmw dealership as they have the same problem with the 5 series and that is the fixI have an 04 plate 1.6 diesel cmax zetec fitted with cvt transmission which has done 39,000 miles. Until recently everything was ok. However about a month ago both front doors started squeaking quite badly when travelling at low speeds.
Brian
#5
Posted 17 November 2008 - 03:35 PM
I see that its now sold in stick form on ebay. I tried everything else but this stuff just works as if by magic.
http://cgi.ebay.co.u...336ba06ffaea0dc
Regards,
Chris
