jeebowhite Posted July 26, 2015 Author Share Posted July 26, 2015 The valve removal is fine ad long as it's been mapped out or is a 1.8,he probably blanked both ends of it. That is certainly my plan long term... Sheds excess weight. 3 Quote Link to comment Share on other sites More sharing options...
Dales Posted July 26, 2015 Share Posted July 26, 2015 Yes both ends been blanked. car hasn't had the remap yet. 1 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 26, 2015 Author Share Posted July 26, 2015 As for the terraclean, yes I got mine terracleaned with the valve on and blank off, then ran it for a few days without the blank - smooth as a factory motor, but put the plate on and the mpg went up further along with the responsiveness. As for the decat, well it could work, perhaps the dpf and sensor can be positioned elsewhere though the better answer would be removal. Sadly though this is illegal and a decay pipe with no dpf would fail an mot. Egr blanking does no harm to performance but the nox levels of course do increase a little, the egr only operates at idle and low speed so makes no real odds over most the travel. 2 Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted July 26, 2015 Share Posted July 26, 2015 It's a 2.2 James - not a 1.8 ! 1 Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted July 26, 2015 Share Posted July 26, 2015 EGRV is not operational at idle James Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 26, 2015 Author Share Posted July 26, 2015 True in which case the egr would have been written out, or a mock valve put in. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 26, 2015 Author Share Posted July 26, 2015 Sorry, my bad, above idle. Under heavy load and at standard Idle the egr is closed though anything ordinarily in the range of 1k to 3k the egr would open under part load,but closes at heavy load 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted July 26, 2015 Share Posted July 26, 2015 Theres a TerraClean place up the road from me, How much does the process generally cost? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 26, 2015 Author Share Posted July 26, 2015 Around 100 quid and about an hour of time 1 Quote Link to comment Share on other sites More sharing options...
theredfox Posted July 26, 2015 Share Posted July 26, 2015 hi lenny where is the terra clean place you mention got a link paul 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted July 26, 2015 Share Posted July 26, 2015 hi lenny where is the terra clean place you mention got a link paul Its up in North Wexford mate:Just answered my own question here in link: http://www.terracleanireland.ie/pricing I've not contacted them yet but i have used AtomEx Diesel Multi- Cleaner Link: http://www.xadoireland.ie/index.php?main_page=product_reviews_info&products_id=26&reviews_id=6&zenid=vbgg4geptune010u3pv4et4vp2 See my Review on there website linked above the image, I put this bottle in with a Tank of fuel prior to having my fuel filter changed as part of a routine service, I wanted a product that would flush through to the filter; any dirt that was likely to be in the tank, This stuff made a great difference to the starting and smoothed out the idle running aswell as a little more free response feeling to the engine. I recommend using around 2-3 weeks prior to changing fuel filter for optimum results from your new filter. I also recommend using a bottle of AtomExTotal flush a few miles before your next oil change to remove the carbon deposits and prolong turbo life by keeping the oil feed pipe clear. Quote Link to comment Share on other sites More sharing options...
Lenny Posted July 26, 2015 Share Posted July 26, 2015 hi lenny where is the terra clean place you mention got a link paul Terra-Clean charging 380euro to clean DPF MFK Autocare charge 350euro to cut it open and gutt it then remap ecu far better job lads cleaner ;) Terra-Clean charging 5h1t the bed 400euro to clean the EGR 400!! eBay sell Stainless Steel EGR blanking plates for less than 5 euro shipped!! Once blanked doesnt need cleaned. Terra-Clean standard fuel injector clean is reasonable enough though 135 euro for engine below 2.0ltr Quote Link to comment Share on other sites More sharing options...
theredfox Posted July 26, 2015 Share Posted July 26, 2015 thanks for link Lenny found operator local to me paul Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 27, 2015 Author Share Posted July 27, 2015 Christ it would be cheaper for you to drive over here and use one of our guys. Mines offering a terraclean service for £99! That does all the hotspots... 2 Quote Link to comment Share on other sites More sharing options...
south_bound Posted July 27, 2015 Share Posted July 27, 2015 Terra-Clean charging 380euro to clean DPF MFK Autocare charge 350euro to cut it open and gutt it then remap ecu far better job lads cleaner ;) Terra-Clean charging 5h1t the bed 400euro to clean the EGR 400!! Ebay sell Stainless Steel EGR blanking plates for less than 5 euro shipped!! Once blanked doesnt need cleaned. Terra-Clean standard fuel injector clean is reasonable enough though 135 euro for engine below 2.0ltr I was thinking exactly the same thing when I saw the DPF and EGR clean prices on that website - does include a normal Terraclean in that price though. You could get shot of both problems for life for cheaper and then pay seperately for the Terraclean. The specialist tuning place I have used a couple of times now does Terraclean as well so I will definately be going there sometime soon after all the good stuff I have heard about it. 1 Quote Link to comment Share on other sites More sharing options...
