Attempted Breakin
Maddog55
 Share
HI I have a 2008 Ford Focus which someone attempted to break into. They seemed to have driven something into the key whole on the drivers side. Now when I put the key in the keyhole it seems to go the whole way in but will not turn. Since there is only one keyhole on the focus I am concerned that if the key fob dies I cannot get into my car. Any suggestions on how I can fix this. Is there any way I can get a key barrel to replace the broke one even if it means another key to open the door manually
Link to comment
It's probably a main dealer thing to be honest.
Link to comment
You can get a lock repair kit from Ford.
it has a new lock mechanism and pegs to rebuild the lock to the original key.
Go to a Ford parts counter and ask for Finis (part) number 1552849, it will be about £32. (check compatibility before buying to be 100% sure).
post-28494-0-91216200-1438159383_thumb.j
If you don't feel confident enough to rebuild the barrel yourself I'd recommend getting a locksmith to take a look at it for you.
If you need to work out how to remove the lock mechanism I have linked to a downloadable PDF Haynes manual that has a section covering lock removal (It's for the pre-facelift Focus but the procedure is the same).
https://www.dropbox.com/s/29gw7sebz6fddj7/Ford%20Focus%202005%20to%202009%20Haynes%20PDF%20Manual.pdf?dl=0
  • Like 3
Link to comment
Hi all Thanks for the Help. I will have a look and see what I can do.
  • Like 1
Link to comment
Keep us notified on how you get on.
  • Like 1
Link to comment
Hopefully you do a better job than the thief.
Link to comment
Hi all Will do. Need a bit of time to have a look at it first bit busy at moment . Looked over the Haynes Manual (what a great help thanks for that) and it seems doable. Will explore the removal and then order a repair kit. Will keep you posted.
Link to comment
post-46575-0-87935000-1439115708_thumb.j
Hi looked at the Haynes manual and said undo star screw after removing the plastic cover on the door. I see a hex inside a bit of plastic see image. Just wondering if this has changed as I do not want to drop it inside the door and then have to remove the door trim it get it back. Looks like the design had changed possibly so as less chance at dropping screw any thoughts
Link to comment
  • 3 weeks later...
That could be right^ them hex bolts are quite difficult to drop as the tool sits inside, if you have a piece of thin but stiff card slide that underneath then if you do drop it you can just tilt the card and it will come back to you anyway.
Link to comment
Hi Nathan,
Got a change yesterday to have a better look at the lock. It is a Torx. The good news is that you do not have to take it all the way out( so no chance of dropping it inside the door). You only have to loosen it off and the Lock pops out. The screw is used as a clamp. The end of the screw sits in a recess in the Lock barrel so when you slacken the screw (a good bit) it is still in the threaded part of the door and the lock drops out. Had a look at the lock and It does not come apart so I will go head and buy are repair kit as suggested and build a new lock. Should drop in easily once completed. Looks like original lock needs to be broke apart to get to the lock part.
Link to comment
Called the Ford Parts people and they can order in a repair kit but they are unsure if they can build the lock. They say that if the old one damaged they might not be able to build the new one. Dose anyone know how to explode the original Barrel as I think I will give this a go myself. I took it apart so far then could not get the Barrel out of the main housing.
Link to comment
Even if its damaged, it wont make any diffence, each peg on the old lock has a number on it, most important thing is when dismantling is to make sure only 1 peg at a time is removed and then kept in order, large sheet of paper to put them on helps. Then its just a case of building new lock up with the new pegs of the correct numbers.
  • Like 2
Link to comment
If they'd taken it they probably would have used it as a getaway car or something. Happened to a mate, was woken up one morning by the rozzers hammering on his door. Turned out someone had taken his car in the night and used it in a ram-raid, they'd driven through the window of a local off-licence and left it there.
How are you controlling the rage that some thieving degenerate !stop swearing! has put their plebby low-life paws on your motor? I'd be fuming.
Anyway, hope you get it fixed!
  • Like 1
Link to comment
Hi Ian
Thats what I thought but getting the inner out of the main body which contains the pegs and springs is a bit of a conundrum. It spins ok within itself when you take off the c clip and remove the locking pin but it dose not want to slide out of the the main housing. There must be some other pin that I am missing that holds it in the main body ??
Link to comment
Did that already. Remember Key will not turn in Tumble as its damaged. But when I strip it back as far as I can it spins fine but as if there was something else holding it in place. Might just order the repair kit and since it comes exploded it might shed some light on how the original one comes apart. Just want to use it as reference to build the new one. Might not need it at all just would speed up the process.
Link to comment
Are they flat and slide into a slot which is flush with the outer of the barrel??
Link to comment
That sounds like them, ive never had to do a door lock barrel on your age focus, but from the info I have there are 2, opposite each other,
Link to comment
post-46575-0-37400800-1441223824_thumb.jpost-46575-0-15611200-1441224375_thumb.jpost-46575-0-33779800-1441224468_thumb.jpost-46575-0-37362400-1441224541_thumb.jpost-46575-0-55495600-1441224620_thumb.j
.post-46575-0-49060900-1441224849_thumb.j
Can't see how this comes apart. Does anyone have exploded view of one of these or a repair kit with its component parts displayed. Frustrated or what
Link to comment
On the right side of the bottom picture, does that straight piece not pull out?
  • Like 1
Link to comment
Clive yes it does but it's the lock for the rotator on the outside. Take it out and you can open the car with a flat screwdriver. Does not allow it to part the barrel
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
