WXC79 Posted October 1, 2015 Author Share Posted October 1, 2015 Ok I placed the video recorder 3mtrs away from the exhaust so you can't really hear the idle properly, a much deeper sound then the recorder shows, but there's clips that show that nicely. Of load revs. Had to turn my iPad to full volume, in the flesh it's actually louder by half again. The amazing thing with this exhaust the harder she revs the quieter she gets! The idle note seems to clip the recorder, making a rasp that isn't present in real life. http://youtu.be/npVn_BU6dzk Better idle version, max of 1500rpm blip of throttle. http://youtu.be/8Z2ArqpSpcE Lovely growl to it, just makes me crave one even more;) Quote Link to comment Share on other sites More sharing options...
Russdaz Posted October 1, 2015 Share Posted October 1, 2015 Isn't it just! Gets a little deeper o boost too, but no louder, which is the part I can't get my head around! It just changes its tone, which means you get no drone! Best exhaust I have ever had! 1 Quote Link to comment Share on other sites More sharing options...
Russdaz Posted October 2, 2015 Share Posted October 2, 2015 Should also point out not only does it sound amazing, it looks very well made, nice looking welds, and compliments the rear of the car nicely too, with the pipes sticking slightly out from the bumper. Been well worth the wait! 1 Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted October 2, 2015 Share Posted October 2, 2015 ^ Yes I agree it looks great, and I was surprised by how much bigger the exhaust tips are than standard. Quote Link to comment Share on other sites More sharing options...
Russdaz Posted October 2, 2015 Share Posted October 2, 2015 True they are much bigger, but really check the bore coming out of the box compared to standard, that's easily twice that of the stock version 1 Quote Link to comment Share on other sites More sharing options...
Will-MK7 Posted October 5, 2015 Share Posted October 5, 2015 Does anyone know if the standard hose clips fit the mountune charge pipes? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Russdaz Posted October 5, 2015 Share Posted October 5, 2015 They do apparently, but the replacement clips are much easier to use. Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted October 12, 2015 Share Posted October 12, 2015 Has anyone replaced the exhaust mounts after fitting the Mountune exhaust, and would this affect the warranty? I think I heard the exhaust bumping against something when driving on a bumpy road yesterday, I assume it was the exhaust anyway. Am I right in thinking that fitting some better exhaust mounts this will keep the exhaust more securely in place, and do Mountune sell them? (can't see any one their site) Quote Link to comment Share on other sites More sharing options...
Russdaz Posted October 12, 2015 Share Posted October 12, 2015 Go back to the dealer doesn't sound as if the fit was right.. With a stainless system it needs to fitted cold, them adjust hot.. If they didn't do a hot adjustment it could just need to be adjusted.. I know Mountune took mine out for a drive after fitting (heard and saw them doing it) then adjusted. 1 Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted October 12, 2015 Share Posted October 12, 2015 ^ Ok I'll give them a call. He said he had checked the clearances and warmed it up, and I didn't notice any knocking until yesterday, but I'll see what they say. Should the standard mounts be ok, and would this exhaust be heavier than the standard one? What adjustment can be done to this exhaust anyway, is it just forward and back a bit where it mounts behind the cat, and then it just sits on the mounts? Quote Link to comment Share on other sites More sharing options...
Russdaz Posted October 12, 2015 Share Posted October 12, 2015 I believe my on is on the original mounts but haven't checked.. You can move them around by bending the mounts. But leave it to the dealer to check.. Won't do any harm to replace with silicone mounts they will last longer. 1 Quote Link to comment Share on other sites More sharing options...
Will-MK7 Posted October 12, 2015 Share Posted October 12, 2015 It will be the rubber mounts mate, as the exhaust is abit heavier they tend to stretch, you can either put some cable ties around them to strengthen them up or upgrade to the focus rs mk2.5 exhaust mounts you can buy them from ford. Sent from my iPhone using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted October 12, 2015 Share Posted October 12, 2015 Thanks Will, I'm taking it back to the dealer tomorrow so will ask them about the mounts. 1 Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted October 12, 2015 Share Posted October 12, 2015 or upgrade to the focus rs mk2.5 exhaust mounts you can buy them from ford Do you know how I can get a part number for these, and will they be the same size? Quote Link to comment Share on other sites More sharing options...
Russdaz Posted October 12, 2015 Share Posted October 12, 2015 Maybe ask Mountune what they use? On side note, how's it bedding in? Seems to get better everything I drive it.. Although a couple of my neighbours arnt to keen. Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted October 12, 2015 Share Posted October 12, 2015 ^ I think it's bedding in nicely in terms of the sound it makes, but it's hard to tell. I'm pretty sure I can hear the turbo when giving it a good rev :) I'll ask Mountune too so then I'll have some more info before I go to the dealer tomorrow afternoon. Quote Link to comment Share on other sites More sharing options...
MarksST Posted October 12, 2015 Share Posted October 12, 2015 Mountune will say it needs adjusting and that they've never had an issue with the mounts. Some people don't have an issue but some will, the exhaust is heavier so is going to put more strain on the OE hangers. RS mounts from Ford 1688752 about £9 each or use powerflex EXH-005 Quote Link to comment Share on other sites More sharing options...
Philf1 Posted October 12, 2015 Share Posted October 12, 2015 I got my silicon mounts off Sico developments eBay shop think they were around £30 Sent from my iPhone using Ford OC mobile app 1 Quote Link to comment Share on other sites More sharing options...
Philf1 Posted October 12, 2015 Share Posted October 12, 2015 Part number is in the picture Sent from my iPhone using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Russdaz Posted October 12, 2015 Share Posted October 12, 2015 Just had a look under neath mine.. Tried getting a photo but struggled to an image. But they look like those yellows ones above but in red. No idea what the normal ones look like. Quote Link to comment Share on other sites More sharing options...
MarksST Posted October 12, 2015 Share Posted October 12, 2015 I got my silicon mounts off Sico developments eBay shop think they were around £30 ImageUploadedByFord OC1444678999.683654.jpg Sent from my iPhone using Ford OC mobile app They are the Ford ones that sico buys from a ford dealer and sends to you when you order them from him. May aswell cut out the middleman and go direct to Ford. Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted October 12, 2015 Share Posted October 12, 2015 ^ Are those yellow mounts the Focus RS ones mentioned above? And I assume I would need 4 of them looking at the pics of the exhaust on the Mountune site. 1 Quote Link to comment Share on other sites More sharing options...
MarksST Posted October 12, 2015 Share Posted October 12, 2015 Yes they are, 3 will be fine although you would probably be ok just changing the 2 on the backbox, I think the one right at the front is a different shaped rubber mount. 1 Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted October 12, 2015 Share Posted October 12, 2015 Is the part number the one in large font i.e. 1 688 752 ? Edit: Just noticed that's the part number you mentioned Mark so that's it then :) Found it on Ford Parts UK: http://www.fordpartsuk.com/shop/ford_focus_rs_2009_exhaust_rear_silencer_bush_f_1688752.htm I'll see what the dealer and Mountune say about the mounts and then might order a couple just to hold it more firmly. Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted October 13, 2015 Share Posted October 13, 2015 Here's the response from Mountune: Yes the exhaust is designed to fit with all of the original rubber mounts. If you've got knocking coming from the exhaust, it simply needs to be adjusted. When the exhaust is fitted correctly there should be no knocking. So hopefully if they adjust it properly it will be ok. Quote Link to comment Share on other sites More sharing options...
