karlos1987 Posted August 2, 2015 Share Posted August 2, 2015 I'm looking for some new ideas to do my focus. I've lowered it changed interior and exterior lights sprayed the alloys grills etc gloss black. Any more ideas would be a great help as I'm stuck now. Lol. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 2, 2015 Share Posted August 2, 2015 How much are you looking to spend mate? Quote Link to comment Share on other sites More sharing options...
karlos1987 Posted August 2, 2015 Author Share Posted August 2, 2015 As much as the Mrs will allow. Lol. No seriously I'm open to anything really. If it's something I have to save up for then I'll save for it. It's a 1.6 petrol by the way. 1 Quote Link to comment Share on other sites More sharing options...
alexp999 Posted August 2, 2015 Share Posted August 2, 2015 Zetec S bodykit? Quote Link to comment Share on other sites More sharing options...
karlos1987 Posted August 2, 2015 Author Share Posted August 2, 2015 Is that just the trim that sticks onto my current bumpers? Plus side skirts. How much would I be looking at for that? 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 2, 2015 Share Posted August 2, 2015 As much as the Mrs will allow. Lol. No seriously I'm open to anything really. If it's something I have to save up for then I'll save for it. It's a 1.6 petrol by the way. Some ideas:NGK Irridium spark plugs, K&N57s-4000 induction kit, Samco induction hose, Thats about all can be done to engine unless upgrading to Piper cam shafts Front tower strut brace Braided brake lines with cross drilled and grooved discs Team Hecko wind deflectors ST Pod with ScanGaugeII installed Dual reverse lighting Sub and amp install Speaker upgrade 10" rear flip down monitor 1 Quote Link to comment Share on other sites More sharing options...
karlos1987 Posted August 2, 2015 Author Share Posted August 2, 2015 Cheers. Cant do an amp and sub install due to needing the boot for the buggy etc. 2 children do not travel light. Lol. I'll have a mooch about on eBay see what I can find. What would I need for the dual reverse light? 1 Quote Link to comment Share on other sites More sharing options...
karlos1987 Posted August 2, 2015 Author Share Posted August 2, 2015 Do you know where I can get a samco induction hose from? All the ones on eBay are for the St or rs. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 2, 2015 Share Posted August 2, 2015 Cheers. Cant do an amp and sub install due to needing the boot for the buggy etc. 2 children do not travel light. Lol. I'll have a mooch about on ebay see what I can find. What would I need for the dual reverse light? Heres the dual reverse light guide has a shopping list with links: http://www.fordownersclub.com/forums/topic/29347-guide-fitting-second-reverse-light-ford-focus-mk25/#entry158997 Choice is yours regarding the sub, But I've a buggy in the boot along with a 10" sub and two amps Sub is off when kids in car of course Guide: http://www.fordownersclub.com/forums/topic/63695-guide-fitting-custom-amp-sub-enclosure-mk2-mk25-focus-2005-2011/ Since you have kids in the back, You may like to view my guide on fitting a 10" roof monitor great for long journeys, Link: http://www.fordownersclub.com/forums/topic/67763-guide-fitting-flip-down-roof-monitor-dvd-to-focus-mk2-mk25/ Do you know where I can get a samco induction hose from? All the ones on eBay are for the St or rs.Here's the hose mate, It is a bit pricey but it is smooth flow and stronger than stock. Link: http://www.ebay.co.uk/itm/220743040915 Quote Link to comment Share on other sites More sharing options...
karlos1987 Posted August 2, 2015 Author Share Posted August 2, 2015 Cheers lenny. I'll take a look St those guides. What sort of benefits would I get with the samco hose? 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 2, 2015 Share Posted August 2, 2015 Cheers lenny. I'll take a look at those guides. What sort of benefits would I get with the samco hose?The stock hose is ribbed which creates restriction in airflow but its cheap to manufacture and bends easily so ford didn't have to spend time creating a bespoke hose, by just fitting this ribbed bendable hose. The performance hose is smooth as glass on the inside, it also has sweeping bends resulting in absolutely zero resistance in air flow, If this hose was fitted along with a K&N E-9289 Induction Filter Link: http://www.ebay.co.uk/itm/K-N-E-9289-High-Performance-Replacement-Air-Filter-/131446800923?pt=LH_DefaultDomain_3&hash=item1e9ad7021b You would have optimum non restrictive cold air induction while retaining the stock induction box. It would result in smoother transition between gears as in the car holds a better momentum and 0-60 would be at its best possible unlock a few horses and optimise MPG, Will also sound good on induction nice whoosh sound. NGK iridium spark plugs would then be the icing on the cake for your engine all three items is the optimum performance its gonna get to be honest. 1 Quote Link to comment Share on other sites More sharing options...
TangoDaz Posted August 2, 2015 Share Posted August 2, 2015 Hi Have you considered fitting a Eonon head unit instead of the factory unit? I have done so and also fitted a reversing camera. The unit also has a DVD player as well as sat nav 2 Quote Link to comment Share on other sites More sharing options...
TangoDaz Posted August 2, 2015 Share Posted August 2, 2015 Just thought DRL also look cool and aren't that expensive 2 Quote Link to comment Share on other sites More sharing options...
WES180 Posted August 2, 2015 Share Posted August 2, 2015 Bigger wheels! 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 2, 2015 Share Posted August 2, 2015 Hi Have you considered fitting a Eonon head unit instead of the factory unit? I have done so and also fitted a reversing camera. The unit also has a DVD player as well as sat nav Just thought DRL also look cool and aren't that expensive +1 DRL Fitting Guide Focus Mk2.5 http://www.fordownersclub.com/forums/topic/28999-guide-for-fitting-daytime-running-lights-focus-mk25/ Reverse Camera Fitting Mk2.5 Focus http://www.fordownersclub.com/forums/topic/65470-guide-fitting-reverse-camera-mk25-focus-2008-2011/ The Eonon Headunit would be a straight swap without the need to fit an aftermarket double din fascia kit or iso adaptor looms, You can recuperate funds by removing and selling the stock bluetooth system and headunit, See my guide here to removing those items however the aftermarket fascia section wouldn't be applicable if fitting an Eonon unit http://www.fordownersclub.com/forums/topic/63689-guide-fitting-aftermarket-headunit-mk25-focus-2008-2011/ Discreet Dual Dash Cam DVR is also a good one http://www.fordownersclub.com/forums/topic/65147-guide-fitting-dual-camera-dvr-system-focus-mk2-mk25/?p=438442 Is that just the trim that sticks onto my current bumpers? Plus side skirts. How much would I be looking at for that?Here's a reference Guide if going for ZetecS kit http://www.fordownersclub.com/forums/topic/33147-focus-zetec-s-kit-fitted/page__fromsearch__1 The kit bonds to existing panels, Guide Fitting ZetecS Front Lip: http://www.fordownersclub.com/forums/topic/32648-focus-zetec-s-front-skirt-lip-fitting-guide-pdf/ Guide Fitting ZetecS Rear Diffuser: http://www.fordownersclub.com/forums/topic/32649-focus-zetec-s-rear-skirt-diffuser-fitting-guide-pdf/?p=255361 Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted September 24, 2015 Share Posted September 24, 2015 how about st leather interior and wire them up so heated as well .powerfold mirrors .st rear spoiler. Quote Link to comment Share on other sites More sharing options...
