Jordan_95 Posted August 5, 2015 Share Posted August 5, 2015 If I bought an ST180 Cat Back exhaust system would it be a straight fit onto my fiesta Zetec S ecoboost 1L ??? Quote Link to comment Share on other sites More sharing options...
Cablelad Posted August 5, 2015 Share Posted August 5, 2015 I think the ST diameter is different. http://www.fordownersclub.com/forums/topic/69316-st180-exhaust-on-10-ecoboost/ Check out this thread mate. 1 Quote Link to comment Share on other sites More sharing options...
Nathan54771 Posted August 5, 2015 Share Posted August 5, 2015 Could easily be made to fit with an adapter, but wouldn't fit the standard zetec s rear diffuser. You'd need to upgrade to the ST diffuser, but then may aswell use the cheaper twin tip tailpipe option for looks if that's all your after. 1 Quote Link to comment Share on other sites More sharing options...
Jordan_95 Posted August 5, 2015 Author Share Posted August 5, 2015 I already have the ST rear valence Quote Link to comment Share on other sites More sharing options...
Nathan54771 Posted August 5, 2015 Share Posted August 5, 2015 just re read and realised you want the full cat back system, presumed it was just the back box. Not sure it'd fit at the cat someone would have to clarify. Otherwise you just join with an adapter if the pipe works different before the back box. Won't make any difference though you know ? Just an expensive way of having twin tailpipes (that on the standard ST exhaust are cheaply tack welded on anyway) Quote Link to comment Share on other sites More sharing options...
Jordan_95 Posted August 5, 2015 Author Share Posted August 5, 2015 Want the twin tail pipes as I have the ST diffuser but what would you recommend then ? Quote Link to comment Share on other sites More sharing options...
Nathan54771 Posted August 5, 2015 Share Posted August 5, 2015 If it's just a cosmetic twin tailpipe your after, see this guide..... http://www.fordownersclub.com/forums/tutorials/article/233-ford-fiesta-mk75-rear-diffuser-upgrade-st/ If you want cosmetic and abit of performance or noise, then go power flow for custom or buy a miltek etc. Quote Link to comment Share on other sites More sharing options...
