AdBlock Warning
Sign in to follow this
Followers 0
iain13
Water Leak
6 posts in this topic
I have recently bought a V reg Focus and have found that water leaks into the front of the car when it rains. The water drips in thought the interior light fitting and onto the gearbox.
At first I thought the water was getting in through the ariel as it was split near the top but i have taped it up and there is no way it can get through there. My next guess is that id is getting in through a gap in the windscreen somewhere or the seal.
Has anyone experienced this problem before?
Any help or advice on what to do next would be greatly appreciated
Cheers
Iain
Cheers
Iain
ive just had a look at mine and to be honest apart from the strips on the roof and ariel i see no other way it could get in is the car on a slope thats the only way i can see rain run along the roof from a leak in the windscreen an old tip i had with a fiat get it into a dark garage etc and use a torch on the outside with someone inside and see idf theres any light coming from anywhere on the roof
i got a leak coming in from the passanger footwell whne the weather is really bad any ideasSS
thanks in advance
thanks in advance
that will be your pollen filter in engine bay
theres a post on here some ware do a search
there s a new updated pollen filter cover qand seal to fix this problem a few mates took theres to ford and had it done free of charge worth a shot apparently when the filter is being done the top cover should be slid upwards and not pulled off and new sealing strips should be put on
Followers 0
