Di1990 Posted August 8, 2015 Share Posted August 8, 2015 I've got a 2002 Ford Mondeo Mistral 1.8 bought a few weeks ago it's been no trouble and still isn't there's just concerning noises coming from the engine. After driving it (not short drives a good half hour or so) there's a hissing noise from behind the steering wheel which I can't hear under the bonnet but it's only when the engine is on. I've been looking on forums and I've found a bit about leaking pipes but I thought if that was the case I'd still hear it when it was switched off. I don't want to go to a garage yet as last time with my old Mondeo that was overheating they flushed the radiator which was quite expensive and it just turned out to be a sticking valve which cost a couple of quid! Any help appreciated. Quote Link to comment Share on other sites More sharing options...
ppeter7 Posted August 9, 2015 Share Posted August 9, 2015 you have the heater matrix behind the dash.Are you loosing water ?? Quote Link to comment Share on other sites More sharing options...
Dales Posted August 10, 2015 Share Posted August 10, 2015 I would say it sounds like it might be coming from the heater matrix too. check see if the floor is damp, but if its only a hissing the floor might not actually get damp certainly. but usually you can smell it if its leaking from inside the car. Either that or you might have a peed off snake under the dash :D Quote Link to comment Share on other sites More sharing options...
