dazloz Posted August 9, 2015 Share Posted August 9, 2015 Hi folks tried having my air con re gassed last week to find that the system had a leak from the compressor Does this mean a new compressor or is it likely to be a pipe replacement? Many thanks in advance Darren Quote Link to comment Share on other sites More sharing options...
WES180 Posted August 9, 2015 Share Posted August 9, 2015 There is usually a UV reactive dye in the gas so a quick scan round with a UV light should show where the leak is. Mine was leaking from the Condenser where a stone had punctured it. It would hold a charge but only for a day. I also had a pipe burst when getting it regassed! 1 Quote Link to comment Share on other sites More sharing options...
dazloz Posted August 9, 2015 Author Share Posted August 9, 2015 I had it done to kwik fit for a no gas no fee and they came back with that it had a leak from compressor And that was it! So I thought I'd put it out there and see wether it was a replacement pipe or the compressor Quote Link to comment Share on other sites More sharing options...
WES180 Posted August 9, 2015 Share Posted August 9, 2015 We cant give a definitive answer mate as it will be purely guessing. You will need to check it yourself or get another garage to look at it. I would get hold of a UV light first and check it out yourself. They dont always put the UV dye in but its worth a try as it wont cost you anything to look. If they are saying its definitely the compressor then why would you suspect a pipe or were they a bit incompetent like other members have found out too? 1 Quote Link to comment Share on other sites More sharing options...
SeanW Posted August 9, 2015 Share Posted August 9, 2015 I had it done to kwik fit for a no gas no fee and they came back with that it had a leak from compressor And that was it! So I thought I'd put it out there and see wether it was a replacement pipe or the compressor Take it somewhere else!They told me exactly the same thing!! Full of the brown smelly stuff that drops out of bovine bottoms 1 Quote Link to comment Share on other sites More sharing options...
