Cliff71 Posted August 10, 2015 Share Posted August 10, 2015 Hi all. Some opinions if you please. This afternoon I've changed the power steering fluid in my 52 plate 1.6. At no point did I run the pump until I'd drained it & refilled, then only briefly to suck it into the system, then refilled again. I was careful to avoid getting bubbles. However, now the steering feels heavier & is juddering. I've double checked the fluid & it's gone foamy on top. Any ideas? Quote Link to comment Share on other sites More sharing options...
artscot79 Posted August 10, 2015 Share Posted August 10, 2015 I asked about this at ford and they never renew the fluid foamy at the top suggests water in the system so it may need to be redrained again or there's a lot of air got into the system from memory you refill start the engine and turn from full lock to full lock a few times recheck fluid level and then poo the lid on Quote Link to comment Share on other sites More sharing options...
Cliff71 Posted August 10, 2015 Author Share Posted August 10, 2015 That's exactly what I did. I'll drain it off again & refill. Hopefully that will sort it. Quote Link to comment Share on other sites More sharing options...
iantt Posted August 10, 2015 Share Posted August 10, 2015 Just leave it overnight and the air in the fluid will rise up to reservoir, if its still the same, you need to jack front wheels off the ground and turn the steering lock to lock a few times, then engine off and leave for as long as you can , this should get rid of the air. Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted August 10, 2015 Share Posted August 10, 2015 I asked about this at ford and they never renew the fluid foamy at the top suggests water in the system so it may need to be redrained again or there's a lot of air got into the system from memory you refill start the engine and turn from full lock to full lock a few times recheck fluid level and then poo the lid on you have too poo the lid on ? no wonder fords charge so much lol Quote Link to comment Share on other sites More sharing options...
Cliff71 Posted August 12, 2015 Author Share Posted August 12, 2015 Thanks all. Drained it again & refilled. All good now. Quote Link to comment Share on other sites More sharing options...
