Abbie1994 Posted August 11, 2015 Share Posted August 11, 2015 My engine fan no longer wants to work I have fitted a new one and changed the fuse and checked the relay is there a way I can check to see if the wires are burnt out or there is a current going to the fan ? Quote Link to comment Share on other sites More sharing options...
DieselPig Posted August 11, 2015 Share Posted August 11, 2015 Find the engine temp sensor and short the leads out. 1 Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted August 11, 2015 Share Posted August 11, 2015 If you've AC, switch it on (should force the fan to come on, obviously if there's a fault it won't come on... and then use a multimeter to test wiring If you don't, do what dieselpig said! :) Quote Link to comment Share on other sites More sharing options...
Abbie1994 Posted August 11, 2015 Author Share Posted August 11, 2015 Thanks Don't have ac unfortunately Will try the multimeter Quote Link to comment Share on other sites More sharing options...
