smak Posted August 18, 2015 Share Posted August 18, 2015 Hello I have a Focus Estate CVT 2006 Model. Every now and then, and most times going over bumps, the computer seems to lose control of everything, loads of warning lights light up and my computer tells me "steering malfunction" "transmission malfunction" when this happens I loose all power to the wheels. I spoke to someone about it and they say it's a common problem and that I must apply pressure to the front of the speedo casing, I tried this and it helps, almost as if there is a loose connection behind the speedo case. I want to know if anyone else has had this problem and particularly with the automatics. And what they did to fix it?? Thanks Guys! Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted August 20, 2015 Share Posted August 20, 2015 sounds very much like the nstrment cluster issues... Quote Link to comment Share on other sites More sharing options...
smak Posted August 26, 2015 Author Share Posted August 26, 2015 Thanks jeebowhite This problem is still occurring with the instrument cluster and since yesterday the engine warning light has come on and is staying on. I am wondering if this is a result of the instrument cluster problem or could it be advising that there is a fault in the engine? What does the warning light refer to? I have seen that you can easily remove the instrument cluster and spray it with some circuit board cleaner, but will this actually solve the problem? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted September 1, 2015 Share Posted September 1, 2015 that error light is a universal "help" message, it just means something is wrong and you need to fix it. You need to read the error codes, but I would say with the evidence so far presented, your best bet is to get it refurbed for £99. If its a no fault found, its about £30, but if it keeps going as it is, I would suggest it will be a refurb jobby. Quote Link to comment Share on other sites More sharing options...
