Maintaining Low Gear In Auto
trevor12
 Share
2015 Mondeo 1.5 ecoboost with 6 speed auto gearbox.
When traveling down steep gradients it is sometimes an advantage to lock into a low gear.
On my new Mondeo the gear selection is prnds, and no selection for 2 or 1. The manual says to engage a low gear for "Gradient assist" press the button on the gear shift. There is no button.
Any suggestions on how to lock into a low gear.
Thanks in advance for any suggestions.
Steve
Link to comment
Is this a '' powershift '' box ?
If so they behave differently to what most would know as an '' automatic '' as, in it's design & general operation it is a '' manual gearbox '' with dual clutches & computer controlled electric servos to change gears
Quite how one locks into a lower gear I have no idea but I'm sure someone on here will know
Link to comment
On my Fiesta Powershift there are two buttons on the gearshift. The one on the front needs to be depressed to move out of Park or into Reverse etc. The other is on the drivers side of the gearshift and lets you manually shift up or down the gears.
Link to comment
I've just read the manual and it says
Press the button on the front of the
gearshift lever to shift to each position.
So there's the normal button to allow shifting in/out of park/reverse etc
Is the same button used so that just pressing it in 'd' engages 'gradient assist' ? seems a bit odd but maybe that's it...
Link to comment
if you put the gearbox into s (sport) mode can you then select whatever gear you require by the rocker button on the shifter?
Link to comment
This gearbox is not a powershift.
The paddles allow you to select whichever gear you wish in sport mode, but do not lock, they will simply change up when the revs increase.
operation of the button on the front of the gear shift does not work gradient assist.
I have spoken to my dealership, who have no idea, and have advised me to talk to their "Master Technician" on Wednesday.
I will pass on any update then.
Link to comment
Final outcome, from dealership.
cannot lock down in lower gear with this gearbox.
Link to comment
Shocking oversight by Fraud design / the gearbox maker
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
