That Guy Posted August 22, 2015 Share Posted August 22, 2015 I know this has been covered many times on here but I am trying to remove the locoing wheel nuts from the two back wheels, I purchased the car but sadly did not come with the key. They are the standard Ford Focus ones, I want to try and remove them with a socket due to very limited funds at the moment. This problem is I have tried a 19mm which is too small even with a hammer and 20mm is too big, I am using 12 point sockets. Does any of the experts who has removed these with a socket remember the correct/best size to hammer on? I will then see if I can buy that size on its own. This is the style I have, there doesn't seem to be a sleeve around them: Thanks in advance! Quote Link to comment Share on other sites More sharing options...
WES180 Posted August 22, 2015 Share Posted August 22, 2015 Have you got imperial sized sockets too to try? Ive done it before the same way youre trying but cant remember what size i used sorry. Quote Link to comment Share on other sites More sharing options...
That Guy Posted August 22, 2015 Author Share Posted August 22, 2015 Have you got imperial sized sockets too to try? Ive done it before the same way youre trying but cant remember what size i used sorry. No sadly not, trying to find a set at Halfords *cringe* or any other place which don't cost a small fortune is hard, may have to look online. Quote Link to comment Share on other sites More sharing options...
STEADS Posted August 22, 2015 Share Posted August 22, 2015 I,ll have a look in my shed in a bit got the one in there somewhere. Quote Link to comment Share on other sites More sharing options...
STEADS Posted August 22, 2015 Share Posted August 22, 2015 15/16th and a 3/4 are the two I tend to use Quote Link to comment Share on other sites More sharing options...
That Guy Posted August 22, 2015 Author Share Posted August 22, 2015 15/16th and a 3/4 are the two I tend to use Perfect Thank You for taking the time to look :) Will save me buying a whole set just for me to destroy a couple of them :D Quote Link to comment Share on other sites More sharing options...
WES180 Posted August 22, 2015 Share Posted August 22, 2015 Ask your neighbours, someone will have one rather than buying new. Quote Link to comment Share on other sites More sharing options...
williamweb Posted August 22, 2015 Share Posted August 22, 2015 I would let you use mine but too far.I agree with Wes must be someone near you with a MK 1. Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
WES180 Posted August 22, 2015 Share Posted August 22, 2015 I would let you use mine but too far.I agree with Wes must be someone near you with a MK 1. Sent from my iPad using Ford OC Why a mk1 lol? He needs an imperial socket set not another car! 1 Quote Link to comment Share on other sites More sharing options...
williamweb Posted August 22, 2015 Share Posted August 22, 2015 That Guy,do you have a MK1? Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
mrnobody Posted August 22, 2015 Share Posted August 22, 2015 use a spark plug socket,tap it on with a hammer Quote Link to comment Share on other sites More sharing options...
That Guy Posted August 22, 2015 Author Share Posted August 22, 2015 Ask your neighbours, someone will have one rather than buying new. Have sent an SOS txt to my contacts asking them to check their sheds :) That Guy,do you have a MK1? Sent from my iPad using Ford OC Yes 2003 MK1 (facelift version I think people call it) use a spark plug socket,tap it on with a hammer This will be another option to try, but been told the 12 point sockets will grip better? Quote Link to comment Share on other sites More sharing options...
Jeremyc Posted August 22, 2015 Share Posted August 22, 2015 Goto your local tyre dealer. Mine was able to remove them without damaging alloy using a specialist removal tool (not a hammer and socket) for £10 for four. Perfect Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted August 22, 2015 Share Posted August 22, 2015 If you bought it from a garage get them to remove the nuts!! If you bought it private, look in all the door pockets and under the spare etc, I've found them in weird places before lol. 1 Quote Link to comment Share on other sites More sharing options...
That Guy Posted August 22, 2015 Author Share Posted August 22, 2015 Goto your local tyre dealer. Mine was able to remove them without damaging alloy using a specialist removal tool (not a hammer and socket) for £10 for four. Perfect Will check the garage behind my work see what they say, from reading posts on here most places seem to charge between £30-£50 to remove them. If you bought it from a garage get them to remove the nuts!! If you bought it private, look in all the door pockets and under the spare etc, I've found them in weird places before lol. Purchased the car privately, glove box and door pockets were empty, checked under spare wheel. Was wondering if there is storage behind the boot wall lining but don't think there is? Quote Link to comment Share on other sites More sharing options...
simcor Posted August 22, 2015 Share Posted August 22, 2015 Try a MR tyre, they have the dynomec nut removal kits, charge usually between £5-10 per wheel. Quote Link to comment Share on other sites More sharing options...
ScaniaPBman Posted August 24, 2015 Share Posted August 24, 2015 Looks like you are not desperate just yet. I suggest that you have a read here and see post #5 for choices. I followed the third line and contacted Autostyle Wheels in Liverpool. He was very helpful and did the biz with a minimum of fuss and bother. You do need a good, detailed, clear, close-up digital picture of the wiggly pattern on the face of the locking nut which he will send off to McGard. They will send you promptly the new key direct from Germany. It's non destructive and economical to do. Of course if your car is now sitting with a flat or bald tyre right now, go for some instant action. If I remember correctly the above method took about a week from first contact to the key dropping through the letterbox. Let's know how you get on. ScaniaPBman Quote Link to comment Share on other sites More sharing options...
That Guy Posted September 1, 2015 Author Share Posted September 1, 2015 15/16th and a 3/4 are the two I tend to use Sadly 15/16th was huge, way too big. 3/4 was just slightly too small to be hammered on, what would the next size up be from this? Quote Link to comment Share on other sites More sharing options...
iantt Posted September 1, 2015 Share Posted September 1, 2015 Have you damaged the locking nuts now? Where In glos are you? Quote Link to comment Share on other sites More sharing options...
williamweb Posted September 1, 2015 Share Posted September 1, 2015 Go to your local Ford garage,they should have a master key for your locking wheel nut.I'm sure if you ask them nicely they will undo for free. Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
Pink Panther Posted September 1, 2015 Share Posted September 1, 2015 A decent mig, a big bolt and 5 minutes is all it takes Quote Link to comment Share on other sites More sharing options...
iantt Posted September 1, 2015 Share Posted September 1, 2015 Go to your local Ford garage,they should have a master key for your locking wheel nut.I'm sure if you ask them nicely they will undo for free. Sent from my iPad using Ford OC Some will for free, but most will charge Quote Link to comment Share on other sites More sharing options...
williamweb Posted September 1, 2015 Share Posted September 1, 2015 Worth a go I reckon. Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
That Guy Posted September 1, 2015 Author Share Posted September 1, 2015 Have you damaged the locking nuts now? Where In glos are you? No damage to them. I'm by Gloucester Docks. Go to your local Ford garage,they should have a master key for your locking wheel nut.I'm sure if you ask them nicely they will undo for free. Sent from my iPad using Ford OC Tried them already the said I would need to buy a key and as its only the back wheels that have them on don't really want to buy the key if I can help it. Quote Link to comment Share on other sites More sharing options...
iantt Posted September 1, 2015 Share Posted September 1, 2015 Ive messaged you chris. Quote Link to comment Share on other sites More sharing options...
