Sign in to follow this
BODGEIT
focus lights problem
Hi,anyone HELP.My focus driving lights have stopped working for some reason unknown,fuses & bulbs all ok,side lights,parking lights ok,high beem works but no longer stays on as it did when fully pulled.Main driving lights only not working at all,seems to be no power getting to bulb end,Could it be a relay.
Any help would be great
Regards
Bodge
Regards
Bodge
could be your switch :(
the relay is the next choice to look at, if this is ok i would suspect the switch.
Hi, I believe this is most likely your rotary light switch
because looking at the circuit diagrams...
- If it was your main beam relay, then your flash would not work
- If it was your dipped beam relay, then your main beam WOULD work
- Also, the flash circuit is the only circuit which bypasses your rotary light switch
