gibbo1471 Posted September 8, 2015 Share Posted September 8, 2015 Hi all I have an annoying clunk knock from front of the car it's been there ages it's more noticeable going slowly over little bumps etc. I have changed the following both wishbones both drop links no broken springs and has passed MOT with no problems if I push on the car up and down can't hear anything any ideas anyone so annoying lovely car apart from that Quote Link to comment Share on other sites More sharing options...
gibbo1471 Posted September 8, 2015 Author Share Posted September 8, 2015 It's a Y reg petrol focus estate sorry Quote Link to comment Share on other sites More sharing options...
Foci_st3 Posted September 8, 2015 Share Posted September 8, 2015 Are they pattern parts or original ford, did you fit them yourself or did a garage do the work for you. 1 Quote Link to comment Share on other sites More sharing options...
stef123 Posted September 8, 2015 Share Posted September 8, 2015 The anti roll bar D bushes are usually worth a look. 1 Quote Link to comment Share on other sites More sharing options...
artscot79 Posted September 8, 2015 Share Posted September 8, 2015 i had the same on my mk2 it was the strut bearing so i replaced the strut top mount and the bearing as well Quote Link to comment Share on other sites More sharing options...
chopper27 Posted September 9, 2015 Share Posted September 9, 2015 Had the same 'clunk' on the nearside found out it was the top mount might be worth a look..? Quote Link to comment Share on other sites More sharing options...
gibbo1471 Posted September 10, 2015 Author Share Posted September 10, 2015 Top mount for the suspension spring/shock u Mean also I might try disconnecting the anti roll bar drop links then drive a little see if noise is still there it's hard to diagnose been to 3 garages in total Quote Link to comment Share on other sites More sharing options...
artscot79 Posted September 10, 2015 Share Posted September 10, 2015 yeah i had ford tell me it was a driveshaft but i could hear if the noise was from lower down or higher up near the mount if youre doing the mount replace the bearing and droplink Quote Link to comment Share on other sites More sharing options...
