Phil 87 Posted September 17, 2015 Share Posted September 17, 2015 I'm tempted by these mist washers, seen them on a Golf which had them as standard and they were great. Are they adjustable like the standard ones or does the mist spray over the whole windscreen? And how do the heated ones work, are there some cables to wire up in the engine bay, and are they set up to come on with the heated screen or with a separate button? Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted September 17, 2015 Share Posted September 17, 2015 They're not adjustable. It covers the whole screen. Heated ones work with the heated windscreen switch I think. The wiring needs to be present & they need enabling 2 Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted September 17, 2015 Share Posted September 17, 2015 I have these on the TXS - they are very effective & the heated function works very well in the winter 1 Quote Link to comment Share on other sites More sharing options...
Philf1 Posted September 17, 2015 Share Posted September 17, 2015 I have the most washers and they are far better than standard Sent from my iPhone using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted September 17, 2015 Share Posted September 17, 2015 I have the most washers and they are far better than standard Sent from my iPhone using Ford OC mobile app They're great Sent from my HTC One_M8 using Tapatalk Quote Link to comment Share on other sites More sharing options...
TitaniumWhite Posted September 17, 2015 Share Posted September 17, 2015 I have the Quickclear windscreen, so is it possible to put heated washers onto the car? Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted September 17, 2015 Share Posted September 17, 2015 I have the Quickclear windscreen, so is it possible to put heated washers onto the car?Depends if the wiring is present/able to be added. It'll then need to be enabled assuming the relevant fuses & relays are present, I believe Sent from my HTC One_M8 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Willy Posted September 17, 2015 Share Posted September 17, 2015 I looked into it and it's not an easy job without cutting wires etc. The fiesta doesn't come with heated washers so there's no bits on the loom. Basically you take the loom from the focus. Quote Link to comment Share on other sites More sharing options...
TitaniumWhite Posted September 17, 2015 Share Posted September 17, 2015 Sounds complicated and expensive. You'd think the Titanium would have had them as standard, considering the cost of it. ^_^ Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted September 17, 2015 Share Posted September 17, 2015 To be honest I can't remember ever needing to use the washers and finding they were frozen. If the washers are frozen then your windscreen is probably covered in ice too, which means you'll be using the heated screen and the wipers. Then by the time you really need to clean the screen the washers will have been warmed up by the engine. 1 Quote Link to comment Share on other sites More sharing options...
666Damian666 Posted September 25, 2015 Author Share Posted September 25, 2015 Are the washers easy to swap over ? Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted September 25, 2015 Share Posted September 25, 2015 Are the washers easy to swap over ?Very Sent from my HTC One_M8 using Tapatalk Quote Link to comment Share on other sites More sharing options...
666Damian666 Posted September 25, 2015 Author Share Posted September 25, 2015 Pop them off with a tool from above the bonnet or from underneath (if that makes sense) Quote Link to comment Share on other sites More sharing options...
Philf1 Posted September 25, 2015 Share Posted September 25, 2015 As said really easy, just pull the insulation back under the bonnet and push them through, disconnect the pipes and then reverse order to fit the new ones. 2 Quote Link to comment Share on other sites More sharing options...
666Damian666 Posted September 25, 2015 Author Share Posted September 25, 2015 I have bought some so will fit them when they arrive 1 Quote Link to comment Share on other sites More sharing options...
Paramanic Posted September 26, 2015 Share Posted September 26, 2015 I had mist jets but sprayed over roof used a dab of super glue to make it spray down but glue never set at all........ But for the wiring of the heated ones you guys are making it so complex why not just add it onto Ur heated wingmirrors ? Would work when u turn on heated windscreen Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted September 26, 2015 Share Posted September 26, 2015 ^ I think the heated mirrors come on with the rear screen. 1 Quote Link to comment Share on other sites More sharing options...
Willy Posted September 26, 2015 Share Posted September 26, 2015 ^ I think the heated mirrors come on with the rear screen. They do. 1 Quote Link to comment Share on other sites More sharing options...
Paramanic Posted September 26, 2015 Share Posted September 26, 2015 A don't know I just press the max button and they come on Quote Link to comment Share on other sites More sharing options...
Paramanic Posted September 26, 2015 Share Posted September 26, 2015 But would this circuit be good enough for the mist jets Quote Link to comment Share on other sites More sharing options...
Willy Posted September 26, 2015 Share Posted September 26, 2015 Just wire it into the heated front screen circuit ;) 2 Quote Link to comment Share on other sites More sharing options...
Paramanic Posted September 26, 2015 Share Posted September 26, 2015 Awww flek aye haha Quote Link to comment Share on other sites More sharing options...
