removing break light fiesta mk 6 - need help.
spamdan08
hi there. i have a ford fiesta mk6. the rear top break light needs a new bulb but i dont have a clue how to remove the light, any help
Check your user manual it should say in there. If you haven't got one, I'm sure you can find one online somewhere.
Open boot, locate hex screws on light cluster and remove (3) get your hand in the boot back of the light cluster ther is another "wing nut" type nut that needs removed, you may have to grip this with pliers to get the initial turn.
Think your thnking of either the n/s or o/s bulbs. The high level is just clipped in (no screws)
Open the boot and remove the two rubber grommets @ the back of the light. Get a light to see into the holes and you will see the metal clips. Get a small screwdriver and prise them up (so your pushing the light out)
I had to do mine today and I had to remove the grommit. The guy who worked in the parts dealer took me through how to do it when I bought the bulbs and warned me that some of the m have the grommit behind the lights and some don't. Make sure your certain you havn't got it on your model before you try pulling out the lights!
