Ford Fiesta 13 Acdamp Smell
tommyaweek
 Share
It's bacteria in the system / air vents - do you use it often ?
Link to comment
Fans are on almost evey day but ac button not on
Usually have the recirculation button (car button)
Link to comment
I have seen on other post that pollen filter may need changing could it be same on my car?
Link to comment
We where on m25 and it on 2 and recirculation and ac on and on lowest temperature
Smell went whilst driving unless i got used to it
Link to comment
Hardly ever have mine on recirc, like fresh air and not stale air going round and round, try a can of anti bacterial air con treatment following instructions on can
Link to comment
I would change the odour/pollen filter if its not been done for a few years.
Link to comment
Assume nothing & change the recirc setting to fresh air :)
Link to comment
Where is pollen filter and would i be able to see if it needs changing
Link to comment
It's buried under the dash and can be a pig to access (think scuffed knuckles and mucho swearing).
Only way to be sure is remove it.
I'd say it definitely needs doing though plus run a can of AC cleaner through too to renove bacteria etc.
  • Like 1
Link to comment
Anyone know of a youtube vid or pictures of specification to do it
Link to comment
Easy, philip screwdriver or small flat blade, and a torx screwdriver or simular, takes all of 3 mins .
Link to comment
Drivers foot well, theres a console side trim panel that runs from clutch pedal area towards gear lever, need to remove the trim retainer either using screwdriver to unscrew centre of it or use flat bladed and lever the centre part of retainer clip. Then pull that panel away and at same time press clutch pedal down so you can rest panel between clutch pedal and brake pedal. That gives you plenty of room to remove the 1 or 2 torx screws depending on age from pollen filter cover,
Link to comment
Thank you for the help
Where is best place for pruce and quality to get kne?
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
