fiesta lynda Posted October 3, 2015 Share Posted October 3, 2015 I have a focus 1.6 petrol Zeneca with a engine warning light alarm which then goes into limp mode !It all stated when the car would not start just would click when turning key calledAA as you do it's a battery proolem ok he got the car going all ok went to halfordchad battery check all ok good battery next day same problem friend put fault code check on found codes cleared all ok went to ford garage to have diagnosed you will need new instrument cluster £500 plus labour !In then mean time if problem persist bash top of dash seams to work spoke to different people don't know which way to go anyone with similar probe thanks Quote Link to comment Share on other sites More sharing options...
briscaF1 Posted October 3, 2015 Share Posted October 3, 2015 Is the instrument cluster working? If so, if you hold the stalk button down at ignition on, you should be able to get to fault codes without an diagnostic tool. If the dealer have diagnosed it, fair enough, but sounds like a dodgy connection. Wiring and connectors normally fail more often than electronic systems Sent from my XT1039 Quote Link to comment Share on other sites More sharing options...
