clair9kids Posted October 7, 2015 Share Posted October 7, 2015 Hi all Ive been having a little problem in my ford focus 1.6 2009 model recently the car is running fine untill you go to overtake by accelerating then all of a sudden engine malfunction pops up on dashboard when the car is turned off for 5 minutes its running fine again been having a look around the pipework today and found this piece of hose which is split can someone explain or identify this piece of pipe and what it does and would this be causing the engine malfunction light to come on,as i think it goes to the turbo somethink like a turbo hose ? ive included a picture hope someone can help me being a female lol many thanks clair Quote Link to comment Share on other sites More sharing options...
simcor Posted October 7, 2015 Share Posted October 7, 2015 That is the turbo inter cooler pipe I would imagine you will be getting smoke as well. It will also be down on power. You need to replace it ASAP. Quote Link to comment Share on other sites More sharing options...
iantt Posted October 7, 2015 Share Posted October 7, 2015 Not intercooler pipe, thats air intake pipe, fits between airfilter housing and turbo intake , will let you know tommorow how much they are from ford. 1 Quote Link to comment Share on other sites More sharing options...
clair9kids Posted October 7, 2015 Author Share Posted October 7, 2015 Not intercooler pipe, thats air intake pipe, fits between airfilter housing and turbo intake , will let you know tommorow how much they are from ford. thankyou would that cause the engine malfunction light to come on or would they be something else thats causing it Quote Link to comment Share on other sites More sharing options...
clair9kids Posted October 7, 2015 Author Share Posted October 7, 2015 ive found this would this be the correct hose i would need http://www.ebay.co.uk/itm/Ford-Focus-II-1-6-TDCi-2004-11-Air-Filter-Intake-Hose-Pipe-1336611-3M519A673MG-/221895539612?hash=item33aa013b9c thanks clair Quote Link to comment Share on other sites More sharing options...
simcor Posted October 7, 2015 Share Posted October 7, 2015 Oopsie yes sorry it is the air filter to turbo pipe. Was posting quickly between work. 1 Quote Link to comment Share on other sites More sharing options...
Martyducati Posted October 8, 2015 Share Posted October 8, 2015 Yep! Turbo boost pipe, NEEDS replacing NOW, this damage is caused by a bad mechanic stressing the pipe during the slightly awkward airbox removal needed during a oil filter change! Fix asap to avoid financial pain! Get a new mechanic! Quote Link to comment Share on other sites More sharing options...
south_bound Posted October 8, 2015 Share Posted October 8, 2015 The plastic bit which clips that end of the pipe onto the engine block seem to snap easily - mine is currently held on using cable ties. I've never seen one with the end nearly torn off though, someone must have pulled and twisted that really hard for it to happen! I don't know if its possible to buy just the plastic end bit which is held to the rest of the pipe with a metal band or jubilee clip. Quote Link to comment Share on other sites More sharing options...
clair9kids Posted October 8, 2015 Author Share Posted October 8, 2015 The plastic bit which clips that end of the pipe onto the engine block seem to snap easily - mine is currently held on using cable ties. I've never seen one with the end nearly torn off though, someone must have pulled and twisted that really hard for it to happen! I don't know if its possible to buy just the plastic end bit which is held to the rest of the pipe with a metal band or jubilee clip. thanks yes i was just hoping to buy the small rubber part but looks like you need to buy the whole thing Quote Link to comment Share on other sites More sharing options...
iantt Posted October 8, 2015 Share Posted October 8, 2015 Its not a turbo boost pipe either, the eBay item you linked to is for earlier 1.6 , depending on when the build date is on your, that pipe is for build date up to jan 08, so assuming yours is 2009 then it wont fit. Has yours got round or square air filter? Seen pipes deterioate there before, combination of breather residue and being rough when doing oil filter. Quote Link to comment Share on other sites More sharing options...
iantt Posted October 8, 2015 Share Posted October 8, 2015 Comes with maf sensor housing the later one, £133 !!!! Quote Link to comment Share on other sites More sharing options...
clair9kids Posted October 8, 2015 Author Share Posted October 8, 2015 Its not a turbo boost pipe either, the ebay item you linked to is for earlier 1.6 , depending on when the build date is on your, that pipe is for build date up to jan 08, so assuming yours is 2009 then it wont fit. Has yours got round or square air filter? Seen pipes deterioate there before, combination of breather residue and being rough when doing oil filter. Hi yes mine is the big round air filter thanks Quote Link to comment Share on other sites More sharing options...
iantt Posted October 8, 2015 Share Posted October 8, 2015 Thats the exoensive one then, have another look on eBay. Quote Link to comment Share on other sites More sharing options...
clair9kids Posted October 8, 2015 Author Share Posted October 8, 2015 yes just doubled checked on my car def looks the wrong one must keep looking thanks Quote Link to comment Share on other sites More sharing options...
clair9kids Posted October 8, 2015 Author Share Posted October 8, 2015 i think this one looks more like it http://www.ebay.co.uk/itm/FORD-FOCUS-1-6-TDCI-AIR-FILTER-FLOW-INTAKE-HOSE-PIPE-7M519A673EJ-1673571-/301723643994?hash=item464021705a Quote Link to comment Share on other sites More sharing options...
iantt Posted October 8, 2015 Share Posted October 8, 2015 Yep, thats the one Quote Link to comment Share on other sites More sharing options...
