Phen0mable Posted October 20, 2015 Share Posted October 20, 2015 Hello. I have a problem with 1st and 2nd gear on my car. 1st gear is so tricky and hard to "push in" that when I move of the gear pop out and makes that weird noise. I know my gearbox needs oil change but I'm more concern about gear synchro ring or gear shift cable that is attached to the gearbox Now - what's the proper name of that cable thing that is attached between gear shift stick and gearbox ? Quote Link to comment Share on other sites More sharing options...
flying clutchman Posted October 21, 2015 Share Posted October 21, 2015 Gearchange cable. There are two. How about reverse? does that select ok? Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted October 21, 2015 Share Posted October 21, 2015 Hope you find out the issue when I had my Fiesta MK7 first gear was tough and it was a pain in the backside selecting reverse without the gears grinding I had to be rolling slightly so it would slip in Quote Link to comment Share on other sites More sharing options...
Phen0mable Posted October 22, 2015 Author Share Posted October 22, 2015 Yes. Reverse is also hard to select. Quote Link to comment Share on other sites More sharing options...
james_60 Posted October 22, 2015 Share Posted October 22, 2015 Hi It sounds like your GearChange Cables need adjustment. Also get the Gearbox oil level checked Jamie Quote Link to comment Share on other sites More sharing options...
Phen0mable Posted October 27, 2015 Author Share Posted October 27, 2015 I'm 100% sure that oil change is needed like NOW :-) Gear change cable need adjustment also sounds OK I hope that my sync rings are in good shape Quote Link to comment Share on other sites More sharing options...
