CREWE Posted November 2, 2015 Share Posted November 2, 2015 Hi can anyone help, I've got a ford focus 2005 reg and I can't get the passenger doors to open with the fob or key in lock , I've found that the only way I can open the other doors is by having the drivers door open and pressing the lock button on fob , and only then will the other doors open . Also the passenger door wont open from inside has to be as described from above before can open Fob locks fine though and does open the boot , recently changed battery as thought it might be that and checked the fusses no problems there either Help anyone please Quote Link to comment Share on other sites More sharing options...
Preecematt Posted November 2, 2015 Share Posted November 2, 2015 Did you re calibrate the key fob Quote Link to comment Share on other sites More sharing options...
CREWE Posted November 2, 2015 Author Share Posted November 2, 2015 I have re calibrated key fob , the issue started pre battery change STILL NO JOY THOUGH ! Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted November 2, 2015 Share Posted November 2, 2015 To clarify is the issue that the drivers door only opens with the key fob. And the other doors remain locked? Quote Link to comment Share on other sites More sharing options...
CREWE Posted November 3, 2015 Author Share Posted November 3, 2015 drivers door opens with key fob and others remain locked, until the drivers door is physically open and then the lock button on fob pressed and only then the other doors will unlock Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted November 3, 2015 Share Posted November 3, 2015 I'm sure that is just they way it's programmed. You need to press the unlock button and lock button together until the lights flash. I'm not 100% sure that's the procedure but that allows all doors to unlock with a single press on the fob. Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted November 3, 2015 Share Posted November 3, 2015 What you want to do is VERY simple. Just hold down the lock and unlock button on your remote until the horn beeps and the lights flash. Then it will unlock with just one press of the button, if you do it again, you'll be back to 1 press unlocks the driver's door, and 2 presses unlocks all the doors. Quote Link to comment Share on other sites More sharing options...
