Lost Both Xenon Headlights
marshal900l
 Share
Hi everyone. I have a 2004 mondeo st220 estate and my drivers headlight went about a week or so ago and the passenger one went tonight. Can anyone tell me if there is a test that I can do to see whether it's the ballasts gone or what before I go spending the money on new headlights with ballasts and igniters. Any help will be great?
Link to comment
Check the fuses & connections between the lights & loom.
Maybe a silly idea.. but would it be cheaper to fit an aftermarket HID Kit than to replace the OEM ballasts & ignitors (aren't they built into one unit?) ?
Link to comment
The fuses are OK replaced with new ones and all connections seem OK as well. Yeah the ballasts and ignitors are built into the unit.
Link to comment
its not the bulbs is it?
I just assumed he had checked :p
  • Like 1
Link to comment
I have bought new bulbs and still don't work. When the lights are turned on the ballasts do not make a noise like they normally do
Link to comment
Checked Fuses?
Sent from my HTC One_M8 using Tapatalk
Link to comment
It's new fuses in as well the old ones weren't blown but I changed them just to make sure
Link to comment
Relays??
Link to comment
Relay is fine just checked with swapping with one I know works.
Link to comment
Possibly is the ballast then
Link to comment
Odd that both go so close together bulbs makes sense but not so sure about ballasts. One way to find out is pick up a used one and fit it?
Sent from my GT-I9195 using Tapatalk
Link to comment
I'm going to do power tests the weekend to try and narrow it down to ballasts, igniter or the actual headlight switch in the car.
Link to comment
Pull headlight switch out , unplug connector and bridge pins 6 and 8 on connector with ign on, see if dipped beam works,
  • Like 1
Link to comment
On the headlamp connector , the feed is pin 14 and earth 11
Link to comment
Ok will give that a go. Are the pins the same one with the switch being an auto one?
Link to comment
They should be as the light sensor is the one that ultimately flicks the switch rather than you. So the electric still flows down the same pins
  • Like 1
Link to comment
So can I fit a aftermarket d2s HID Kit to a manufacture factory fitted xenon lights with no modifications?
Link to comment
Assuming it's the same type bulb I don't see why not
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
