Sraffie1 Posted November 17, 2015 Share Posted November 17, 2015 Hi all, Having problems with my 53 plate connect clutch. The master cylinder started leaking and I lost the pedal.Its now in a garage and had the master replaced but they are telling me the gearbox now needs to be removed because after around half an hour of bleeding the clutch system and being able to drive the van the pedal fades and con not select gears. Does this sound right or are they just trying to gain extra money from me/ Thanks Martin Quote Link to comment Share on other sites More sharing options...
stef123 Posted November 17, 2015 Share Posted November 17, 2015 Could be correct, been there before with a clutch which was bled using a pressure bleeder. It would last 2 weeks though before fading until the point it was useless. Damaged seal on the slave cylinder. Quote Link to comment Share on other sites More sharing options...
Sraffie1 Posted November 23, 2015 Author Share Posted November 23, 2015 Thanks Stef, That seems to be the problem with mine. They pressure bleed it and pedal lasts around 5hrs before it fades again. M Quote Link to comment Share on other sites More sharing options...
