Quick Power Steering Replacement Question
cbirchy87
 Share
Hi!
So the PAS pump has gone and will be replaced at the weekend. I have also purchased a new union nut. I have researched this am i right in thinking the pipes also need replacing also? I say this as it seems the the union can only be removed when cutting the pipe........
I hope im wrong,
Link to comment
I was told a new nut was needed when replacing the pump.....is the wrong.
Cant you replace the pump without changing the nut and pipes?
Link to comment
Actually , you can reuse the pipes, you have to remove the pipes and pump together , and undo union , there was an issue with pipes leaking at union so the pioes were cut off to remove union in situ then new pipes and union was required, if your renewing pump then the union will be of no use to you as wont get old one off pipe,
Link to comment
So if im just replacing the pump, i wont need new pipes or union?
Link to comment
Nope, but a new sealing washer on the end of union you will need , or carefully remove the one on the new union you have.
It is restricted to undo union even out the vehicle, thats probably why some end up changing pipes also
Link to comment
Well this is embarrassing!
After taking the car to a indy and ordering the parts. it turns out the issue was no steering wheel fluid in the tank! Garage said they checked this before handing over the £320 quote.
I guess my problem now is where did it all go?
Link to comment
3 places, either externaly from pipes leaking, pump leaking or rack leaking internally and filling up in rack boots
  • Like 1
Link to comment
Thanks, Ill have a dig around. will use some card to check for a leak first.
Link to comment
You've gotta notice that on your driveway lol? Why did the garage not diagnose where the leak was?
Link to comment
The car is parked on the road, I did notice oil makes on the road but ignored it as work is being completed on my block of flats. im going to leave some card under the car to check.
Link to comment
  • 7 years later...
Quick question, I have purchased a used but good power streering pump which still has the union nut installed. Can I reuse this or will I have to put in a new union nut?
Link to comment
On 12/1/2015 at 1:28 PM, TomsFocus said:
Why does the nut need replacing? Are they one use on these?
the morons used a quick release coupling - snap and connect with NO way to sensibly get it off again
they also fitted weak pipes that after fighting for space doing an alternator or cambelt - likely stressed the high pressure pipe till it will fracture shortly after - which is likely why it now needs a pump - Ford redid the pipes with an upgraded spec including a support arm (that gets in the way of fitting it !!!) to stop the fracture and fluid loss
the upgraded pipes I believe are sold at cost - as there was a legal fight over the stupidly of the original design - both times I had to get them they were STOCK items at my local dealership - but last was last 4 years back - so less likely now
Link to comment
This thread was posted in 2015. :unsure:
  • Haha 1
Link to comment
and there was a question about it posted - 16 may -  can you read?
Link to comment
I appreciate an old post but mine is dead at my daughters atmo, i think my pump has gone, whine that gets louder with increased revs, change of note waggling the steering and small oil drops on the road also burning off somewhere as slightly smoking. Plenty of fluid in the resevoir. Hope mine has the cheaper end of pump allegedly £160 - £560 in parts.
Link to comment
You didn't quote that post or answer it directly though.  The recent poster probably didn't even get a notification for it.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
