Leechy Posted September 24, 2009 Share Posted September 24, 2009 Hello people, I am new to this site. I have just brought a G reg xr3i with a Efi engine. when my mate saw it he started going on about how good this engine is and how easy it is to mod. is this true? what other engines are there? Quote Link to comment Share on other sites More sharing options...
vinnyvangough Posted September 25, 2009 Share Posted September 25, 2009 The EFI (Electronic Fuel Injection) now the most common fuel system, the injectors spray fuel into the air/intake ports for combustion inside the engine. MFI Abbreviation for Multi-port Fuel Injection, a type of fuel injection system that has one injector for each engine cylinder. Each injector sprays its fuel directly into the intake port in the cylinder head. Multi-port fuel injection is considered to be the "hot" setup because it provides better cylinder-to-cylinder fuel distribution for more power. Both engines are moddable. Quote Link to comment Share on other sites More sharing options...
Leechy Posted September 26, 2009 Author Share Posted September 26, 2009 Thanks for reply. What mod should i do first? Quote Link to comment Share on other sites More sharing options...
vinnyvangough Posted September 26, 2009 Share Posted September 26, 2009 Best thing to start with would be to help the engine breathe more easily. 1 - Uprated air filter, you'll be better of going for a K&N panel filter 2 - Exhaust, go for a 4-2-1 exhaust manifold, slightly larger bore exhaust with a de-cat fitted such as a Mongoose system or such. Then later on you could always start with headwork, such as port polishing, cams etc etc Quote Link to comment Share on other sites More sharing options...
Leechy Posted September 26, 2009 Author Share Posted September 26, 2009 Thanks for advice. Quote Link to comment Share on other sites More sharing options...
vinnyvangough Posted September 26, 2009 Share Posted September 26, 2009 No problem mate Quote Link to comment Share on other sites More sharing options...
