Mondeo 2.0 Tdci 2009 - Immobilizer Active
lukasc
Hi everyone,
Has anyone had an issue where the "Immobilizer Active" message shows when trying to start their car?
Mine wont start now because of this warning message, and ive tried the following so far:
1. Tried both keys and both do the same.
2. Disconnected the battery for 10 mins and reconnected but same result.
Ive not yet checked the fuses as ive just driven 6 hours (in work's car) back from Cornwall so ill check it tomorrow, but can anyone offer advice before i call an auto electrician?
Many thanks
Lukasc
Sounds like the car needs repairing to the key. I think the immobiliser has forgotten which keys are allowed to start the car.
Ok so update - things arent looking good.
So ive checked the battery, was over 12.5v.
Ive also had the laptop plugged in via an ELM 327 HS/MS switchable cable and read the fault codes. Heres the bumf:
Quote
===PCM DTC P0113:00-25===
Code: P0113 - IAT Sensor 1 Circuit High Input
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
===END PCM DTC P0113:00-25===
===PCM DTC U0129:00-2F===
Code: U0129 - Lost Communication with Brake System Control Module A
Status:
===END PCM DTC U0129:00-2F===
===OBDII DTC P0113-P===
Code: P0113 - IAT Sensor Circuit High Input
Status:
- Pending - malfunction is expected to be confirmed
Module: On Board Diagnostic II
Diagnostic Trouble Code details
This DTC may be caused by :
Open Circuit
Signal shorted to VBATT or vref.
Sensor Previously disconnected.
Faulty Sensor
Faulty or damaged PCM.
Extreme low ambient temperature.
Improper connection
Incorrect VREF.
SIGRTN open circuit
===END OBDII DTC P0113-P===
===SASM DTC None===
Successful DTC reading, no error codes found
Module: Steering Angle Sensor Module
===END SASM DTC None===
===BCMii DTC U0121:00-6C===
Code: U0121 - Lost Communication With ABS Control Module
Status:
- DTC Maturing - Intermittent at Time of Request
- Test not complete
Module: Body Control Module
Freeze Frame :
-GLOBTIM: 2561762 sec - Global real time
-TOTDIST: 132475.0 km - Total Distance
-MAINECUV: 11.75 Volt - Main ECU voltage supply
-ESTSERUN: No - Engine status - engine running
-ESTSECRK: No - Engine status - engine in crank
-INCARTMP: 11 °C - In car temperature
===END BCMii DTC U0121:00-6C===
===SRM DTC None===
Module: Speech Recognition Module
===END SRM DTC None===
===PDM DTC None===
Module: Passengers Door Control Unit
===END PDM DTC None===
===DDM DTC None===
Module: Drivers Door Module
===END DDM DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===PAM DTC U0422:00-2F===
Code: U0422 - Invalid Data Received from Body Control Module
Status:
Module: Parking Aid Module
Freeze Frame :
-OUTTMP: 9 °C - External Temperature From Sensor
-INCARTMP: 12 °C - In car temperature
===END PAM DTC U0422:00-2F===
===HVAC DTC None===
Module: Heating Ventilation Air Conditioning
===END HVAC DTC None===
===IPC DTC U0422:68-2B===
Additional Fault Symptom:
- Event Information
Status:
Module: Instrument Panel Control Module
===END IPC DTC U0422:68-2B===
===IPC DTC U0415:68-2B===
Code: U0415 - Invalid Data Received From ABS Control Module
- Event Information
Status:
===END IPC DTC U0415:68-2B===
===IPC DTC U0416:68-2B===
Code: U0416 - Invalid Data Received from VDM
- Event Information
Status:
===END IPC DTC U0416:68-2B===
Now, ive already swapped the ABS Module for another second hand unit and it made no difference (possibly because it needs to be coded?) But im starting to think its either the PCM or the ECU. Not good :-( :-( :-(
(BTW ignote the IAT sensor fault - ive got the air filter out of the car at the moment.)
When the codes are cleared do they all come back?
Sent from my GT-I9195 using Tapatalk
Yes they were cleared several times (even tried the reset PCM module using FORscan).
Ive left the battery disconnected tonight to give it a good chance to clear overnight, though I'm not optimistic about it working.
  • 4 weeks later...
Hi lukasc,
Would you mind giving me an update on your car. We seem to have the same problem. Left 57 plate Mondeo (1.8 Tdci) for 3 weeks at manchester airport over xmas 2015. Returned to find it with immobiliser active on display. Assumed this had been triggered by a low battery after 3 weeks of no use. Green flag could not fix it, auto- electrician could not fix it but he said one of the error messages related to the ABS system. The car is with Ford today. £97/hr to hook up to their diagnostic machine!!!
I hope you got yours fixed. Any advice for us?
Mine turned out to be the ignition feed wire near the fuse box/battery had corroded. Not sure what module the feed was for. Certainly worth checking out before you start disconnecting the ABS pump like I did!!
Can't tell you exactly where it is because it was a ford specialist garage that found it in the end.
I don't think the Mondeo likes standing in cold damp weather for weeks
Also worth noting that the Silver Calcium batteries as fitted to Mondeoes won't recharge if they have become flat.
So our diagnosis from ford is that the whole ABS module needs to be replaced £1100!!! plus the £300 they have racked up diagnosing this problem. Looks like we will have to scrap the car as it is probably only worth about £2000 to trade in. It was running perfectly, it just seems bizzare.
Should we trust ford? Or should we try another garage? Can anyone recommend a mechanic in the chester area?
Laura
why do not recharge with the silver calcium battery?
Cos if they have gone flat they don't recharge
  • 4 years later...
I have a mondeo 2008 and its been going fine. Went to go out today and it wouldnt start, was beeping when i turned the ignition and now it say immobilser active and wont click or start at all. Any ideas? I ve disconnected the battery to see if it clears it.
  • Haha 1
  • 6 months later...
