Hi there. I got a Focus 2006 Mk2 1.6 with 20,000miles. I seem to have some sort of knocking noise when i let the clutch out a little to quick when pulling away in first gear. It also seems to happen when i go from 1st to 2nd. If i let the clutch out really slowly, the knock seems not to be there. Could it be engine/gearboxs mounts!!!
Thanks for any info or help
BR
Steve
Knocking noise when engaging clutch or changing gear
Started by bristolblue, May 21 2008 12:49 PM
2 replies to this topic
#1
Posted 21 May 2008 - 12:49 PM
#2
Posted 21 May 2008 - 01:01 PM
Yes, it could be the engine/gearbox mountings, check them first and that the exhaust manifold>downpipe is secure.
#3
Posted 22 May 2008 - 08:33 AM
BR
Steve
Got the same with my 2005 MKII and only has 4,000 miles on it. Been into fords a couple of time with it regarding this issue and first thing they suspected was one of the gearbox mounts had some play in it, so that was changed but noise is still there, went back with it again and they said they would give it a thorough going over, found nothing faulty anywhere, all they did say was that it was something to do with the gearbox end float , where the driveshaft locates in the gearbox and due to the play in the driveshafts (if you grip the driveshaft and move it in a sideways direction there is play here, but shouldn't be play if you try to move them in direction of rotation which it doesn't) and hence when taking up drive you get this knocking sound , they say this is normal on these and nothing wrong!! can't help thinking this is the usual fob off!!
Cheers Pete
Latest Comments
More
