Please Help!
ash90
 Share
My car is over revving on its own without accelerator being pressed and picking up speed on its own when I switched it off it had trouble starting back up then after about 30minutes it started no problem. The car drives fine for about 5minutes before it starts revving and picking up speed. Any idea of the problem please?
Link to comment
Throttle position sensor most likely or Idle Air Control valve sticking - take it out and give it a squirt and a clean with WD40.
Remove the TPS connector wire and see if it fixes the problem - if it does as I suspect it will then its the TPS.
  • Like 1
Link to comment
I have found the part to buy for throttle position sensor but after looking under the bonnet it looks as though the part is very concealed in. Any tips on how to change this cannot find any help videos for a 2006 ford ka
Link to comment
I removed mine a few weeks ago - wasnt that difficult although my car is a Streetka.
Not sure how different the engine is to be honest but all it took was to remove the throttle body (4 screws) and air box and pipe to get into it.
Removal was then simple.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
