Dcakula Posted January 5, 2016 Share Posted January 5, 2016 I bought my Ford Focus Mk2 in early 2005 - everything was fine with the car until the warranty expired and the Power Assisted Steering Pump and hoses failed. Ford quoted £800 to replace the pump and hoses. I rang Ford to complain that the pump should last for longer thsn 3yrs 6 months and due to my complaint they agreed to pay 45% of the cost. My car is now 11yrs old and done 94 000 miles. This week the hydraulic hoses have again failed but this time the pump is fine. I have contacted Ford to request recompense towards the refitting of new hoses - this appears to be a common fault on the Mk2 Focus - if I do not get anywhere with this issue then I will take it further to the government to ensure that Ford admits t o this expensive problem. Quote Link to comment Share on other sites More sharing options...
dezwez Posted January 11, 2016 Share Posted January 11, 2016 11 years is a bit old for ford to do anything about it sad fact is parts wear out :( 1 Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 11, 2016 Share Posted January 11, 2016 Good luck with that one. 3 Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted January 11, 2016 Share Posted January 11, 2016 ello all, Ford did revise the part for the MK2 Focuses basically the new part removes the actual power steering cooling pipes that lead to the front of the car, in front of the radiator. So if you have power steering pipes that are in front of the radiator near the bottom you have the old power steering pipes which will have issues like exploding pipes or snapping. The revised part does not come with the cooling element and resolves the issues. Just a heads up really, they have released a revised part. Regards Quote Link to comment Share on other sites More sharing options...
dezwez Posted January 11, 2016 Share Posted January 11, 2016 i think they would go down the path of wair wear and tear Quote Link to comment Share on other sites More sharing options...
