sjs Posted September 30, 2009 Share Posted September 30, 2009 Hi, i need to change a rear wheel bearing in a 2003 festa and was wondering if it is a diy job or not, i have heard they can be a nightmare to press out, any ideas?, does anyone know the procedure?. Thanks, Quote Link to comment Share on other sites More sharing options...
stef123 Posted September 30, 2009 Share Posted September 30, 2009 Hi, i need to change a rear wheel bearing in a 2003 festa and was wondering if it is a diy job or not, i have heard they can be a nightmare to press out, any ideas?, does anyone know the procedure?. Thanks, unless you have a hydraulic press i would leave it. you could however buy the bearing, removing the drum and take all the parts down to a local garage and ask them to swap the bearings Quote Link to comment Share on other sites More sharing options...
sjs Posted October 1, 2009 Author Share Posted October 1, 2009 Thanks, do u think it would be possible to do with a heavy bench vice?, does anyone know the torque setting for the hub nut?, cheers. Quote Link to comment Share on other sites More sharing options...
mickk Posted October 24, 2009 Share Posted October 24, 2009 Replaced both of mine myself with no problems. Tapped them out with a drift and pushed the new ones in with a vice using appropriate sized spacers. Manual recommends using a new hub nut with a torque of 275 Nm. Really straightforward. Quote Link to comment Share on other sites More sharing options...
stef123 Posted October 24, 2009 Share Posted October 24, 2009 if you have a large socket or similar the same size as the bearing it is possible to use a large vice as i have done this myself. usually a bearing kit comes with a circlip and hub nut. the rear hub nut torque is 235Nm not 275Nm as presumably haynes? recommends. Quote Link to comment Share on other sites More sharing options...
