Woodywoodster Posted January 10, 2016 Share Posted January 10, 2016 Hi. I have a 52 plate 1.9tdi Galaxy and the left indicator will not flash, it will only light up all left side bulbs and the light on the dashboard. It stays lit even when he stalk has clicked back up. The only way to get the lights to go out is to have the right indicator on! When the indicator is on, you can very faintly hear the 'tick tock' noise. I've been told it could be the relay in the fuse box (not sure how this works as the indicators aren't on a relay!) or it could be the stalk itself. Any suggestions please?! Quote Link to comment Share on other sites More sharing options...
Johnboyad07 Posted January 13, 2016 Share Posted January 13, 2016 Have you disconnected the battery to see if make any difference I know it sound stupid lol Quote Link to comment Share on other sites More sharing options...
SeanW Posted January 13, 2016 Share Posted January 13, 2016 Sounds like an earthing problem. Clean up all the contacts on the light loom Quote Link to comment Share on other sites More sharing options...
Dan62 Posted January 14, 2016 Share Posted January 14, 2016 Hi. I have a 52 plate 1.9tdi Galaxy and the left indicator will not flash, it will only light up all left side bulbs and the light on the dashboard. It stays lit even when he stalk has clicked back up. The only way to get the lights to go out is to have the right indicator on! When the indicator is on, you can very faintly hear the 'tick tock' noise. I've been told it could be the relay in the fuse box (not sure how this works as the indicators aren't on a relay!) or it could be the stalk itself. Any suggestions please?! The left and right indicator relays are internal components of the fuse box, as is the flasher control circuitry. I think you need a replacement fuse box. Quote Link to comment Share on other sites More sharing options...
gregers Posted January 14, 2016 Share Posted January 14, 2016 also worth checking the fuse board in the engine bay. you also have a pm. Quote Link to comment Share on other sites More sharing options...
SeanW Posted January 16, 2016 Share Posted January 16, 2016 Before diving in and changing fuse boards, go for the cheaper option and check the earths. Used to be a very common fault on the Mk2 Punto rear light clusters Quote Link to comment Share on other sites More sharing options...
